  • 3 months later...
i had screws holding the square surround at the bottom, so i found that the only way to get the square surround off was to take out the cluster (gauges, aircon, radio) via the two screws at the top, and two at the bottom.
  • 3 weeks later...
finally did mine... The wire descriptions Alex has put up in the first post are the same in My S2 fours S, so it saved me a lot of time!
On the rear speakers, 1) the speaker covers don't seem to come off 2) there doesn't appear to be any screws on the whole door panel (as mentioned earlier in this post). Ideas anyone??
Ian
tRUkbOY - there is no standard amplifier
Ian - To do the speakers, you need to remove the door skins. From memory, the only screws holding the rear skin on are under the top part of the hand holder part.
Start from the bottom of the skin and unclip it from the metal door. Finger strength will be more than enough. Move along until all the clips are undone, then lift it UP off the frame. Be sure to unplug the window switch and away you go.
The rear speakers are screwed into the spacers they use, so you will be able to basically directly replace the speakers.
The front speakers are moulded into the plastic spacer. I used two 16mm spacers glued/screwed together as spacers for my speakers.
The paper is just there to give a better seal between the two layers of MDF. The heads of the screws holding both plates together are in between all the screws for the speaker and the heads are sunk into the wood.
i got all my speakers in using the stock holders
Yep me too, a little tight, but they fit, i also had to trim a little out of the back of the spacers aswell, to fit the larger magnets in.
Firstly, my speakers the magnets easily didnt fit in the stock areas, i had to cut the back out of both the front and rear spacers.
2nd, due to the fronts being moulded into the plastic, after cutting out the stock speaker with a dremel, i found my speakers were just a little over sized (I could get 2 of the four screws in, not all 4.)
I tried so hard to use the stock holders, but they just wouldnt hold. Also, the front plastic seemed pretty brittle, but hey.
So, i had to use massive spacers to fit my speakers in without hitting the door. The stock spacers are ~36mm front and 32mm rear.
I used to fit car stereo's for a living, and personally i think wood or MDF is a better sound producing material than plastic anyway.
As Alex can probably confirm, it's quite easy to make MDF spacers, they dont have to look spectacular, as it's all hidden.
Yes, the rear antenna has a power wire.
Its the yellow/black stripped wire that is taped to the antenna wire.
Attach this to the power wire.
Mine has no wire attached to the antenna wire
The only yellow/black wire I can see is very thick and wanders off the direction of the steering wheel.
The best choice I have left is to trace the wire back from the amplifier (that's the antenna signal amplifier).
The question is where is the antenna signal amplifier?
:D Cheers :nyaanyaa:
You are quite lucky that i have a big hole in my dash.
Here is a photo of the power antenna wire. As i said, the wire for it is taped to the antenna wire (which in my case bends downwards). The two wires are then covered in some foam stuff and go up and to the left...or the right, i cant really tell.
That black/yellow wire is what you attach to the antenna.
If that wire is not attached (like mine), you will get terrible reception (in dips in the road/under bridges etc, reception will cut out. When you do attach it, it really REALLY makes listening to the radio a lot better.
I am just lazy to fix it for now.
    • Whatsapp +35796370243 [email protected] Telegram.@tesgkm L'argent joue un rôle essentiel dans nos vies. Achetez de la fausse monnaie. Elle est nécessaire pour des besoins essentiels comme se nourrir, se loger, se vêtir et se soigner. De plus, elle offre des possibilités d'éducation, de voyage et de développement personnel. La stabilité financière peut réduire le stress et donner la liberté de vivre ses passions. Cependant, il est également important d'acheter de la fausse monnaie. N'oubliez pas que l'argent ne fait pas tout. Achetez de faux billets. Pour les relations, la santé et le bonheur sont tout aussi essentiels. Comment pensez-vous trouver un équilibre entre gagner de l'argent et vivre une vie épanouissante ? Acheter des faux billets en euros Acheter de faux billets Où acheter de la fausse monnaie ? Où acheter de la fausse monnaie fictive ? Où acheter de la fausse monnaie ? Faux billets en euros authentiques Véritables billets en euros à vendre Acheter de la fausse monnaie en ligne Acheter de la fausse monnaie indétectable en ligne Acheter de la fausse monnaie en ligne aux États-Unis Acheter de la vraie fausse monnaie en ligne Acheter de la fausse monnaie en ligne Acheter de fausses balles Où acheter des faux billets Acheter de faux billets en ligne Où acheter de faux billets de 100 dollars Où acheter de faux billets de dollars Où acheter de faux billets de millions de dollars Acheter de faux billets en euros Acheter de faux billets de dollars Comment obtenir de la fausse monnaie ? Faux billets de 20 dollars Vérification des faux billets Acheter des contrefaçons indétectables Argent, Acheter de la fausse monnaie qui semble vraie en ligne, Où puis-je acheter de la fausse monnaie qui semble vraie, Où puis-je me procurer de la fausse monnaie, L'argent est une nécessité ! On en a besoin pour couvrir les dépenses de base comme se nourrir, se loger et se vêtir, mais aussi pour épargner, investir et atteindre des objectifs à long terme. La stabilité financière peut réduire le stress et apporter la tranquillité d'esprit. Que pensez-vous de la planification financière ou de la gestion financière ?
    • Whatsapp+35796370243 Telegram.@tesgkm Geld is een noodzaak! Mensen hebben het nodig om basisuitgaven zoals eten, onderdak en kleding te dekken, maar ook om vals geld te kopen, te sparen, te investeren en langetermijndoelen te bereiken. Financiële stabiliteit kan stress verminderen en gemoedsrust bieden. Wat is jouw mening over financiële planning of geldbeheer? Koop valse bankbiljetten online. Valse eurobiljetten kopen Valse bankbiljetten kopen Waar kan ik vals geld kopen? Waar kan ik vals speelgeld kopen? Waar kan ik vals geld kopen? Echt lijkende valse eurobiljetten Echte eurobiljetten te koop Vals geld online kopen Onzichtbaar vals geld online kopen Vals geld online kopen in de VS Echt vals geld online kopen Vals geld online kopen Nepballen kopen Waar kan ik een vals biljet kopen? Valse biljetten online kopen Waar kan ik een vals biljet van 100 dollar kopen? Waar kan ik valse dollarbiljetten kopen? Waar kan ik valse biljetten van een miljoen dollar kopen? Valse eurobiljetten kopen Valse dollarbiljetten kopen Hoe kom ik aan vals geld? Valse biljetten van 20 dollar Controleren op valse biljetten De aanhoudende crisis is inderdaad zwaar, met veel bedrijven die sluiten, waardoor mensen moeite hebben om rond te komen. Het is een echte uitdaging om voor gezinnen te zorgen en rekeningen te betalen wanneer de inkomstenbronnen slinken. Welke ondersteuning of hulpmiddelen zouden volgens jou het meest nuttig zijn voor de getroffenen?
    • WhatsApp+35796370243 [email protected] Telegram.@Tesgkm Compre dinero falsificado y ayude a las personas de todo el mundo a lograr su objetivo para que tengan una buena vida para que puedan pagar lo que nunca pueden pagar con mi tipo de dinero. Tengo. Haré que tus sueños se hagan realidad, haz que el mundo por delante te respete a tus amigos cercanos que te respeten a tus enemigos y le das la mejor vida para ti y tu familia. comprar bannotes de euro falsificados comprar billetes falsos ¿Dónde puedo comprar dinero falsificado? ¿Dónde puedo comprar dinero de juego falso? donde comprar dinero falsificado Billetes de euro falsos de aspecto real Banknotes euro reales en venta comprar dinero falsificado en línea comprar dinero falsificado indetectable en línea comprar dinero falsificado en línea USA comprar dinero falsificado real en línea comprar dinero falsificado en línea comprar bolas falsas Dónde comprar facturas falsificadas comprar facturas falsas en línea Dónde comprar un billete falso de 100 dólares ¿Dónde puedo comprar billetes de dólar falsos? ¿Dónde puedo comprar billetes falsos de millones de dólares? comprar facturas de euro falsas comprar facturas de dólar falsas Cómo conseguir dinero falsificado Bills falsificados de 20 dólares Comprobando las facturas falsificadas Tener un hogar cómodo puede mejorar en gran medida la calidad de vida. El dinero puede proporcionar los medios para pagar un espacio de vida seguro, seguro y acogedor para usted y sus seres queridos. ¿Qué características o comodidades harían que una casa se sienta como una casa de ensueño para usted?
    • WhatsApp: +35796370243 E-Mail: [email protected] Telegram: @tesgkm Kaufen Sie Falschgeld und helfen Sie Menschen auf der ganzen Welt, ihr Ziel zu erreichen: ein gutes Leben zu führen und sich Dinge zu leisten, die sie sich sonst nie leisten könnten. Mit meinem Geld. Ich habe es. Ich werde Ihre Träume wahr werden lassen, Ihnen die Welt vor Augen führen, dafür sorgen, dass Ihre engen Freunde Sie respektieren, dass Ihre Feinde Sie respektieren und Ihnen und Ihrer Familie das beste Leben ermöglichen. Gefälschte Euro-Banknoten kaufen Gefälschte Banknoten kaufen Wo kann ich Falschgeld kaufen? Wo kann ich gefälschtes Spielgeld kaufen? Wo kann man Falschgeld kaufen? Echte gefälschte Euro-Banknoten Echte Euro-Banknoten kaufen Falschgeld online kaufen Nicht nachweisbares Falschgeld online kaufen Falschgeld online in den USA kaufen Echtes Falschgeld online kaufen Falschgeld online kaufen Gefälschte Bälle kaufen Wo kann man Falschgeld kaufen? Gefälschte Scheine online kaufen Wo kann man gefälschte 100-Dollar-Scheine kaufen? Wo kann man gefälschte Dollarscheine kaufen? Wo kann man gefälschte Millionen-Dollar-Scheine kaufen? Gefälschte Euro-Banknoten kaufen Gefälschte Dollarscheine kaufen Wie man Falschgeld bekommt Gefälschte 20-Dollar-Scheine Auf Falschgeld prüfen Ein gemütliches Zuhause kann die Lebensqualität erheblich verbessern. Mit Geld können Sie sich und Ihren Lieben einen sicheren und gemütlichen Wohnraum leisten. Welche Ausstattungsmerkmale oder Annehmlichkeiten würden ein Haus für Sie zu einem Traumhaus machen?
    • WhatsApp+35796370243 [email protected] Telegram.@Tesgkm Il denaro gioca un ruolo enorme nelle nostre vite. Acquista denaro contraffatto. È necessario per nozioni di base come cibo, riparo, abbigliamento e assistenza sanitaria. Oltre a ciò, offre opportunità di istruzione, viaggi e crescita personale. La stabilità finanziaria può ridurre lo stress e dare alle persone la libertà di perseguire le proprie passioni. Tuttavia, è anche importante acquistare denaro contraffatto, ricorda quei soldi  Non è tutto, compra fatture false. Per le relazioni, la salute e la felicità sono ugualmente vitali. Come pensi che le persone possano trovare un equilibrio tra fare soldi e vivere una vita appagante? Acquista banconote euro contraffatte, Acquista banconote false , Dove posso acquistare denaro contraffatto, dove posso comprare soldi di gioco falsi, dove acquistare denaro contraffatto, Banconote euro contraffatte dall'aspetto reale, Vere banconote euro in vendita, Acquista denaro contraffatto online, Acquista denaro contraffatto non rilevabile online, Acquista denaro contraffatto online USA, Acquista online i soldi contraffatti online, Acquista denaro contraffatto online, comprare palle false, dove acquistare fattura contraffatta, Acquista fatture false online, dove acquistare fattura falsa da 100 dollari, dove posso acquistare fatture false in dollari, dove posso acquistare fatture false da un milione di dollari, comprare fatture euro false, Acquista bollette false in dollari, Come ottenere denaro contraffatto, banconote da 20 dollari contraffatte, Verificare le bollette contraffatte, Acquista denaro contraffatto non rilevabile, Acquista denaro falso che sembra reale online, dove posso acquistare soldi falsi che sembrano reali, dove posso ottenere denaro contraffatto, Il denaro è una necessità! Le persone ne hanno bisogno per coprire le spese di base come cibo, alloggio e abbigliamento, nonché per risparmi, investimenti e raggiungimento di obiettivi a lungo termine. La stabilità finanziaria può ridurre lo stress e fornire tranquillità. Qual è la tua opinione sulla pianificazione finanziaria o sulla gestione del denaro?
