  • Replies 43
Originally posted by KamikazeR33
im sure this topic already came up joe :D
I am sure it has but that is just plain wrong advertising...
Some people think they know everthing even without do research!
Man I would be pissed off if you buy that car and find out it's just plain old RWD! not 4WD as it said. wouldn't you?
cheers
Joe
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124493
The R33 GTS-t 4WD does exist, but I only know of one in WA, so I expect that they are a very rare factory production. Similarly to the R33's with the VSPEC diff and such these cars came out with a feature that was not in the normal production. I'm not sure if it was ever considered a factory option, or whether they just produced them to see what the effect was.
Anyway I can say with some authority that it does exit, although the likelyhood of seeing one is very low.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124705
GTS-t VSPEC. The model you are talking about with the vspec diff was released as a production model, just in very limited numbers. I did have the specs for it somewhere and it was a fair bit more expensive than the normal gtst too when new. Never ever heard/seen of a factory awd gtst tho.
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124799
Yeah I feel kind of lucky to pick one up, knew that they were limited.
I'm guessing that the car I saw might have been one of the in-house models from Nissan, they do make some to order for the big tuning houses aswell.
I'm not mistaken by what I saw, I was there with a Engineering who does certification of ADR's, and he had never seen one either. Possibly not a production model, but too stock to have been aftermarket job.
See'ya:burnout:
https://www.sau.com.au/forums/topic/8534-r33-gts-t-4wd/#findComment-124808
    • List all of your mods. It sounds like an aftermarket ECU hitting rev limiter. Like a valet mode, or a cold rpm limiter?
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
