Hey
When driving my oil presure gauge sometimes drops all the way down to sitting just about the 0. When i start the car it goes up to 4 but when i drive it mainly sits on the line below the 4. Any ideas why it would be doing this ? Car hasent lost any power. Car is a R32 GTR
Thanks
Edited by BNR
https://www.sau.com.au/forums/topic/85663-oil-presure-question/
It may be the sender.
Mine does this 'occasionally', the little ol rb20 did this as does the rb30. My sender is dicky and appears to play up 'occasionally' when it gets hot. Completely random, then all of a sudden its ok again.
It may be the oil your running?
My oil pressure when cold is well over the 8. Idle is inbetween the first and second line. Cruise is some where above 4 and above 3500-4000rpm is up around 7. :)
I'm using an rb25det pump.
  • 7 months later...
if the sender is stuffed, does that mean if u put an aftermarket guage on you will still see the same results as the stock guage ??....
just out of interest.. where abouts is the sender... or how would u go about hooking up and aftermarket one :) ?
Even the R34 sender is crappy. It's the one thing Nissan didn't seem to figure out.
the sender is screwed into the block about 1.5 inches the rear of the engine from the oil filter.
you would replace or use a T piece to screw in both senders. ( i have a thing about dash guages still working even though i have aftermarket)
in the pic below the sender is screwed in where the line going from bottom left to top right of the block is.
Edited by Craved
cool thanks heaps for that :)
if the sender is broken though.. wouldnt it send incorrect results to the aftermarket guage still ???
aftermarket guages come with their own sender ... thats why you use a T piece so they are both hooked up and working (even if stock one is wrong)
yeah, i would say the sendor unit a swell. mine is sitting just above 0 as well when it idles hot. then pulled the sendor unit apart, it was actually leaking oil through it. then put on a mechanical oil pressure gauge, and the reading is on 2.5 bar hot idling, which is fine.
apparently according to Nissan, when the rpm is at 950, the oil pressure should be on 1.5 bar hot, which proved mine was fine.
  • 8 months later...
somthing to chew on
when you fill your engine up with oil and you fill it to the top of the full line on the dip stick the oil presure should be 3.9-4.0 cold 1.9-2.5 warm.
but if you fill the engine to 2mm below the full mark on the dip stick the oil presure cold is 6.8-8.0 and 2.5- 4.0 warm the big question is what is better for the engine.
does it work like this lower presure lower oil flow warmer engine? or higher oil presure higher flow warmer engine?
i am lost at what to do i will leave it to the brains trust
SK will probably know what to do
The oil when under pressure creates a very thin film of oil between the two surfaces keeping them (in a way) insulated from each other.
Thats what i think is called pressure lubrication where as in say a gearbox they utilise a splash lubrication.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
    • This coupled with 6-9 speed autos with ridiculously short gearing is why these modern shitbox cars always seem so fast off the line. If it wasn't for those things, Raptors would not seem fast. The problem we have is there is a driveability gap between a more gentle take off and a wheelspinning sideways launch. The difference between ankle flex required to achieve one and ankle flex required to achieve the other is about 0.5°.
    • Yeah I think I'm also with the opposite here. It's 'hard to keep up with traffic' because in the real world I'm accelerating with 15% throttle and they are pinning it. It feels like I'm being an overt dickhead at anything above 15% throttle, so the car sounds like I'm being an overt dickhead to keep up with/get ahead of traffic when I'm really just trying to drive with traffic. There would be no issue 'keeping up with traffic' if we used the same level of throttle input/aggression to drive around. People really do just drive around with their foot nearly pinned in econoboxes.
    • To be fair it's the other way around. 300kw is boring in a modern Golf or BMW. They are so competent / well-engineered / devoid of emotion that you have to go stupid fast to feel anything. Whereas the <300kw RB still makes all the right noises and it feels good to drive. Can pull off at the lights with the turbo whooshing and the blow-off pssshing and feel like the coolest kid on the block. Just don't look to the side where you'll see the bored housewifes in their shitbox Yaris/Corolla/Camry that kept up because you didn't go fast at all
    • 300kW is so boring in a Skyline, you'll get spanked by someone's mum's Golf with Alibaba pipes, and an email tune.
