Makes A Bit Of A Difference....
By shubby0901 · Posted
Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms! Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings! -
I guess. The diff and the speedo are gearbox agnostic.
@GTSBoy sorry I still am unable to pm direct
So I'm.about rhe manual swap my 34gt sedan, I've already done a +T I'm just wanting to clarify that I'm not goin to need to do anything with a speed sensor on the box for the speedo to still operate as it is supplied a signal from the diff correct?
Welcome. As the old saying goes, there's no replacement for displacement(except boooooost!) The 3.7 v6 has a lot of capacity over the 2.5 straight 6. Add forced induction and will definitely add to the fun factor. But, probably not going to be a cheap exercise. I'm sure you will have a fun journey either way.
