  • 4 months later...
  • Replies 50
  • 3 weeks later...
rdirty32,
How much for the Steering Wheel + Centre Piece only? Without the Steering Column.
Also, please calculate REGISTERED MAIL postage to postcode 6149 in Perth, Western Australia. Cheers.
e-mail to: [email protected]
  • 1 year later...
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
