Yeah, they look reasonably similar
Ghostrider - I'm probably going to stick a PI donk in it soon, we've got a few spare, just cant be bothered changing the tank and fuel lines atm. I would just go for a TC or S engine for the extra torque over the 2 litre, but if I'm going to do it I want it to sound good... and sticking filters on each throttle on a PI engine and junking the standard plennum makes a fantastic noise, its rorty, growly and just generally fantastic. Plus we've got them down to a fine art now, basically never have problems because we get the guy in Sydney that tunes the mechanical injection metering units for the Forumla 5000 and Historic Touring car guys to do the units and send them back. Only problem is injector 5 sometimes getting an air lock, just leave the engine running, pop the bonnet, pull the injector out and tap it a few times with a spanner, then stick it back in
That said the FJ20E is appealing as it will rev a bit more, probably be lighter and will sit back a bit more
Edit - Oh, and as to where the engine came from, as far as I know its just an extended version of the Triumph / Standard 4 cylinder (which was a Massey Ferguson tractor engine) but with a narrower bore? Could have been the same as the Vanguard six?
Edited by Adam_RSX
  • 5 months later...
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
    • thanks GTSboy. My confusion at the moment is i am trying to locate the ignition, ECU battery power and the ECU negative The closest thing i can find is the for the S15 on Page 8 of the Wiring Specialties web page https://drive.google.com/file/d/0B9F33_M_GgENQnZ6STMxVmVNd1E/view?resourcekey=0-eZ4nNRwRoqa1qvKlWWHm8A I cannot find the same diagram for the R33 RB25DET Series 2 dash plug pin out.... Do you know what the Pins? or know where i can find the same pinout diagram for the RB dash plug? Thanks for the advice on the box... i like a 6 speed so might be on the lookout or the box now.. a topic of discussion for another post...
    • Will have a look at that. I cant see any leaks
    • Put another overflow bottle (ie, a 1.25 coke bottle or similar) under the overflow hose and see if it is being pushed out there or if it is disappearing into the engine.
