I was wanting to do something different with my R33 Dash Piece that goes from the gear stick, up over the climate control and stereo deck, and around over the top or the steering wheel to the other side.
I want to make it a new colour, has anyone else done this before? Can someone guide me to some pics perhaps and does anyone have suggestions of what colour I should go for and how to do it.
I was thinking a nice random bright orange or a blue, the car is gun metal grey and the interior is all dark in colour. I was thinking rubbing down the plastic and then going over it with some plastic primer and then what paint do I need to use?
All help/suggestions/advice and comments are appreciated.
Thanks,
[ SKYRYAN ]
https://www.sau.com.au/forums/topic/86527-custom-dash-colour/
simple go to your local paint place and ask them what they recomend
i just lightly sanded to get rid of original flakey coating plastic primed then top coated you can then clear but i was woried bout reflection/ glare
my dash surround is in a light grey with the feature pieces ( inst cluster speaker grills etc) round the cab in a light metallic blue
all done at home in the shed with spraypacs
only problem with making a new colour is u gotta remember the mixture levels and stuff.. i did a mix of red a while ago and the guy that did it for me just went "ohhhh lil of this that and the other" and then we found it hard to match :P
just make sure u make enough of the paint if u need to do other parts of the interior or what ever :)
im takin mine to an airbrush artist, gettin him to throw out some ideas. , or some grapha mates might have a go at gettin somethin goin, thats my 2 cent's, its white atm but man it sucks when ya on ya 4th coat or white then bam!! ya get one tiny bit that didnt take, gotta peel it all of again. ill try find some pics
    • I mean, I got two VASS engineers to refuse to cert my own coilovers stating those very laws. Appendix B makes it pretty clear what it considers 'Variable Suspension' to be. In my lived experience they can't certify something that isn't actually in the list as something that requires certification. In the VASS engineering checklist they have to complete (LS3/NCOP11) and sign on there is nothing there. All the references inside NCOP11 state that if it's variable by the driver that height needs to maintain 100mm while the car is in motion. It states the car is lowered lowering blocks and other types of things are acceptable. Dialling out a shock is about as 'user adjustable' as changing any other suspension component lol. I wanted to have it signed off to dissuade HWP and RWC testers to state the suspension is legal to avoid having this discussion with them. The real problem is that Police and RWC/Pink/Blue slip people will say it needs engineering, and the engineers will state it doesn't need engineering. It is hugely irritating when aforementioned people get all "i know the rules mate feck off" when they don't, and the actual engineers are pleasant as all hell and do know the rules. Cars failing RWC for things that aren't listed in the RWC requirements is another thing here entirely!
    • I don't. I mean, mine's not a GTR, but it is a 32 with a lot of GTR stuff on it. But regardless, I typically buy from local suppliers. Getting stuff from Japan is seldom worth the pain. Buying from RHDJapan usually ends up in the final total of your basket being about double what you thought it would be, after all the bullshit fees and such are added on.
    • The hydrocarbon component of E10 can be shittier, and is in fact, shittier, than that used in normal 91RON fuel. That's because the octane boost provided by the ethanol allows them to use stuff that doesn't make the grade without the help. The 1c/L saving typically available on E10 is going to be massively overridden by the increased consumption caused by the ethanol and the crappier HC (ie the HCs will be less dense, meaning that there will definitely be less energy per unit volume than for more dense HCs). That is one of the reasons why P98 will return better fuel consumption than 91 does, even with the ignition timing completely fixed. There is more energy per unit volume because the HCs used in 98 are higher density than in the lawnmower fuel.
    • No, I'd suggest that that is the checklist for pneumatic/hydraulic adjustable systems. I would say, based on my years of reading and complying with Australian Standards and similar regulations, that the narrow interpretation of Clause 3.2 b would be the preferred/expected/intended one, by the author, and those using the standard. Wishful thinking need not apply.
    • Yes they do. For some maybe. But for those used the most by abusers, ie Skylines, the numbers are known. The stock eyebrow height for R32/3 Skylines is about 365/375mm or thereabouts. The minimum such heights are recorded in adjacent columns in the database.
