Will you be getting in any of these seats that are fully blue along with the shipment of seats that are fully red? Will be interested as soon as I can get some dimensions for the seats.
  • Replies 175
Posted Images
Hi mate, thanks for your enquiry. Unfortunately we dont have any all blue versions of the Bride style seats coming, only black with the blue centre (which are in stock now)
Dimensions below as posted on page 2
Hi guys, approximate dimensions of the seats are as follows:
Overall Height: Approx 90cm
Widest Point: Approx 53cm (shoulder to shoulder)
Internal width at rear of base: Approx 33cm (actual seating area)
Internal width at front of base: Approx 36cm
Note: We now have 5 sets of black with grey centre, 4 sets of black with red centre and 4 sets of black with blue centre remaining so get in quick to avoid missing out.
The black/red version is winder type, and the black/grey and black/blue versions are lever type
Cheers,
Steve
Cheers,
Steve
I'll take some measurements from my bride rail shortly and post them up and hopefully JJ can do a quick measurement on their seats ;)
JK
ok these measurements were taken from the centre of each hole.
Front left to front right 285 to 300mm
Front left to rear left 330mm
can you plz measure the seats? thanks
J
Will keep you posted Jaik, I shall get the guys to do these when they have a moment
Steve
w00t. I should also mention the Bride rails have one normal round hole (front right) and the rest are elongated at around 30mm, basically allowing the installation of a seat of approximately the width ive listed above.
JK
Also interested in a all-black set of seats for my R33.
Out of curiosity, do you have any seats currently in stock that are the same style as the black ones? I only ask as I wouldn't mind coming down to have a look first before going ahead with the purchase.
Thanks
Thanks
Hi mate, we sure do. Feel free to drop by anytime and have a look
Regards,
Steve
about how much would it be to get the rails modified? very interested but jus abit worried about the installation cost haha. and would you guys do an install service?
The modifications to the universal rails to get them to fit your car, it's a simple welding job right? My mate is a welder who could do it for me for nothing if this is the case (he's a professional). Or is the mod something you need to get done by an approved workshop for safety reasons?
Hi mate, thanks for your enquiry. The modifications required are generally minor depending on the car the seats are being installed in.
We recommend having them fitted by a knowledgable workshop or competant welder.
Cheers,
Steve
if they do bolt straight up to brise rails, how much can we purchase bride rails for?
We found that the genuine Bride rail needed a few minor changes before the seat could be bolted up as 1 or 2 of the holes didnt quite lineup and had to be redrilled on the rail itself to suit
Cheers,
Steve
Thanks JK, which email did you send it to?
Feel free to pm me
MSPEC: Confirming if we have a set of the black with grey centre in the showroom, will let you know shortly.
Thanks
Steve
    • As I've said elsewhere, I am using the stock intercooler piping path in the engine bay, and a return flow cooler, and making ~250 rwkW (without any effort put into trying to turn it up past there just yet) and expect to be able to make some more, and frankly, I would be perfectly happy with 260-270rwKW. This is peak road Skyline usability territory. You go past there and, sure, the car will snap necks more when it's on boost, but it will also break shit all the time, cost a (even larger) fortune in tyres, etc etc. Anyway, I also do not like the over-the-fan pipe path, and you don't have to do it.
    • I see, honestly I’m not too fussed about the looks. The only reason to go plenum is to make the piping easier instead of the classic over the rad etc.
    • Not easy to quantify wrt something like how many fractions of a second slower it would be over 0-100. But given that a 250-300rwkW car is able to do that launch sprint in 5-6 sec (and faster with appropriate tyres, and surface)..... giving up as much as a second would feel like torture. A ~450HP capable turbo is not going to make lots of boost in the 2000-3000 rpm range. So, whilst with some boost on hand it will be faster accelerating in that rev range than your engine currently is NA, it will not feel like a fast car until the boost is solidly in. You know what your car feels like right now when you open it up at 2000rpm. if you've ever been in an actual fast car, you will appreciate that the NARB25 is.... not exciting. Well, add some boost and it will be better. But shorten the intake runners and it might not be better at all. It might come out better, but it could end up feeling the same. For me, it's not the 0-X km/h sprints that matter. It is easy to fry the tyres with anything over 200 rwkW. You can't use all the power available in 1st and 2nd anyway, you have to modulate the throttle. What matters is how the car reacts when you're driving in traffic in 4th or 5th and have maybe 2000 rpm on board, and you want/need to add some speed quickly, and don't have time for the downshift. It won't make boost, it will be all NA (at the speeds we're talking about - remember how fast you're going at 2000 in 4th! and don't plan on breaking the limit by too much.) So giving away NA torque is not what I would consider practical for a street car. And retaining that NA torque builds boost faster which makes the car faster. The flashy plenum is not actually better, unless you're looking at a track car where you can keep it on the boil all the time.
    • So how much difference does it make you think? Like 1 second in the 0-100?  I was have smaller turbo so hopefully that spools quick GTX2871.  currently it’s NA so you can imagine pretty slow, but I do want fast accusation a little as there’s not many places I’ll be driving where I go over 80 even near me. So 0-60 and 0-80 targets
    • Short inlet runners cost quite a bit. Dulls off the off-boost torque, and delays boost onset, because arrival of boost is driven by gas flow is a product of the ability to flow air which is torque. This is the reason that the stock manifolds have longer runners. On a 3L, or bigger, you can usually accept the compromise of giving away some torque because the extra capacity gives you a little extra to waste. But on a smaller motor, there's not a lot there to start with. Example, I swapped RB20 out of my R32, 25NeoDET in its place. The "wall of torque" that I experienced afterwards made it all worthwhile. That's because I came from RB20 land where torque is not a thing. But I would not do anything, anything at all, to reduce the low/mid torque I have now, because I remember what it is like to not have it!
