1996 Nissan Skyline GTS-t Series 2
Type M bodykit
5speed manual
Black
92,000klms
Dual Airbags
Factory wheels with new tyres
Aftermarket cat back exhaust
Aftermarket airfilter
Boost gauge
Alarm
Turbo Timer
Top of range Sony CD tuner with flip down face
10months registration
Roadworthy certificate
Asking $14,900 for QUICK sale as owner going overseas
E-mail [email protected] for pics and more info
Edited by mcboom
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
