Your car looks tops all painted up mate, much better with the white bonnet. I reckon a set of low offset meshies and you'll be done.
Jap import spares have some awesome new wheels in stock, a new container just landed.
Yeah matsuri was awesome, shame it rained almost all day but i still had fun. first time in over 3 years so it took a while getting used to it again!!!
Thanks, yeah I've been looking through their meshies for sale lately, I think my favourites are the VS-XX and Stitches so far, but open to suggestions. Still have the S2 grille to put on, which I reckon would look good with silver meshies. I should really take one of my P1s off to check the size and offset...
Edited by Stang
I don't really get the whole meshies on cefiro thing.
Personally I think you should follow similar path to me, and get rims similar color to the body of the car.
Something 5 spoke.
Looks heaps tougher IMO.
http://www.skylinesa...-1307340538.jpg
Maybe some white TE37s or Drifteks.
Anyway on that note: Looks f**king awesome all painted up.
Why did they paint over the cornering lights on the front bar ??
Edited by Nic_A31
the p1s look ok on your car (ok i personally hate p1s , but it's not my car) , i wouldn't stress too much , if your set on meshies though , go for a set with flat dish like the vs-xx (i.e the band is flat , not stepped like the other rims pictured) , make sure they're clean like the car (maybe even paint the center white for something different?, only if they aren't chrome , i have a lil thing for chome ) , and as much dish as it will handle (and maybe 18" if you can find them) front and rear and then , stance , stance makes a ceff as much as wheels do , look at kris's last pic ^^ for a reference :)
Something 5 spoke.
Thanks, yeah pretty happy with it looking a lot cleaner compared to when I first bought it. Not perfect, but it's an old car.
I do like 5 spokes, and had pondered Meisters as well...but I don't exactly have a lot of money to throw around. Not sure Drifteks would suit it. Not like it's a big rush to get everything at once anyways, tempting as it is.
Wasn't using the cornering lights and thought it would look less busy if they were painted the same as the rest of the bar.
please dont put drifteks on it
:laugh: Don't worry, I won't. ;)
I quite like the P1s really. Since I've only just recently recovered enough to start driving the Ceffy again and doing some mods, I've been getting a bit excited thinking about various options for appearance and power. I do like meshies on quite a few Jap cars I see. Stepped rims can look good, or a bit odd, depending on the car of course.
At the moment it's about as low as I would want to go without beaching it on anything higher than a $2 coin, have already scraped on small speed bumps a couple of times. Kris' Cef does have an awesome stance, but cops here would probably shoot you in the face for that combo of rims and ride height. :laugh:
I'll keep looking around at pics of various wheels and stuff anyway. But may go for some more fasts rather than expensive rims. Making 139rwkw on standard boost and tune at the moment with FMIC and exhaust.
Edited by Stang
^^ THIS MEANS WAR FOOL! :spank:
actually i think SA police would be much nicer then VICpol :glare:
looks like she's in good hands by the way its progressed. did you end up getting some lean air flow ratio's during dyno run if so care to state xx:xx ratio?
I'm not sure, I was really worn out after being at the workshop for a while taking photos, so didn't ask too many questions. I mainly just wanted to make sure it was running ok after only being started once between June 2010 and May 2011.
Here's the readout from the dyno run, I'm not smart enough to know exactly what all the details mean...
Something 5 spoke.
I do like TE37's or even low offset CR Kai's on Ceffy's but drift teks.... :yucky:
Im over seeing Ceffy's with urgays kits and drift teks.
Personally, meshies with dish & slammed.
i like the P1's on your car aswel they suit it, have a look at Works510's car aswel with p1's looks decent
if you want more stance pump the guards and put big f**k off tires on em to scare kids and shit
Edited by Kris..
It's been a while since you posted in here , any updates on the c33??
Couple more from Matsuri. Again, quality of the pics are sub-standard!
Just one I took on the weekend
Your car looks good mate , was that the rb25 one with the laurel dash?
    • looking for some help and maybe some insight on others experience with a new LSD. R34 GT ran and drive beautifully, but always alot of grip loss due to the open R200 rear end, so I just installed a new 1.5 LSD way into the stock open R200 for a ER34. Simple. Everything seemed right. I test drove for the first time this weekend. as I started to back out the garage the first time slowly with tires straight it sounded and felt like I had a loose or half disconnected drive shaft...that was clucking around loose and shaking entire vehicle, and making it feel like the trans clutch was spontaneously slipping then grabbing very roughly while just letting out pedal slowly. I backed it out went to pull forward with the same noise, shake and slip grab feeling with hesitation, I turned the tires to back out more and then pulled ahead some same thing but worst because of added wheel resistance (which that I expected) puzzled … pulling it back in checking everything over and finding nothing wrong, I tried it the next day. same thing, couldn’t believe how it shook everything again making a terrible noise and making it feel like the trans clutch was slipping and grabbing, but I got it out of garage into the driveway, got it straight, drove forward and then reveres a few times in a straight line everything shaking , causing what felt like clutch slip and grab every time, sounded like right behind front driver tire and I could feel it in the floor board with my feet,... worst right when beginning to let clutch pedal out to engage slightly, shuttering and sounding terrible along the way…I managed to slowly get down the road, babying it the whole way, once I was rolling (out of 1st) seemed to be better and between shifts, then clutch felt closer to normal…not slip/ grab etc., but back down to any stop, straight road or turning, same thing. Made no difference if all tires were straight or if I was turning. All other gauge read out correct. with in 2 miles as planned I reached the empty parking lot and performed the break in procedure that came with lsd, essentially to drive in a figure 8 a bunch.  Did this, binding chattering, and shaking the car the whole way. I drove it back home seemed somewhat normal once I was in straight line and past 10 mph or so, and I know it will “bind” on corners and cause some tires squeal when turning especially from a stop, but when I begin to move it still causes what feels like the trans clutch to slip and jerk badly as well as shaking the entire car, and sounds terrible, that I didn’t expect. I used the fluid they supplied with LSD kit and did the breaking, planning to change fluid as they suggest after breaking, but wondering will it get smoother or less aggressive with use? maybe a 1.5 is just too aggressive for normal road driving?   I have a LSD that I put in my 71 cuda when I restored it, with amazing smooth , quite yet effective results. Different style LSD but that ones a joy to drive. maybe expecting too much from this R200?
    • Join SAU NSW for a flame-grilled feed & flame-spitting cruise! Sunday 17th August 2025 3:30PM Meeting Archies Flame Grille Sylvania Waters 4:45PM Cruise Departure 5:15PM Arrival at Cape Solander Kurnell Meet Location: Archies Flame Grille Final Destination: Cape Solander Kurnell *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
    • Yeah good luck out there! Will be good to see a mighty GTST going harder than the GTRs
    • i will be there 😁
    • Hello!  i just finished manual swaping my r34 skyline with a r33 rb20de box(RB71C)box  When the car is running it squeaks crazy loud and it was smoking from the gearbox area. The gearbox is fine it was tested. The clutch slave cylinder seems like it doesn't fully releases the clutch. I want to ask if this noise is from the throw out bearing or could it be the clutch assembly or disk att.xFliq87Gzw6kImKBVqDebXkj0fBqymk0JaYeP3_3SlM.mp4
