Hi Guys,
I recently put a X-force turbo back exhaust system on my R33 GTS-t but it seems to be coming loose from the turbo.
The front pipe and dump is one peice so there isnt much flexibility.
I have had it seeled twice now and just same thing keeps happening.
Has anyone else got this same problem with the Xforce or other brand system?
Best way to resolve issue?
Thanks
Stel
https://www.sau.com.au/forums/topic/87101-exhaust-leak/
ive also got a 2 in 1 piece dump/front pipe but have never encountered this problem before (installed for 2yrs now). you are saying that it leaks at the gaskets where the turbo to dump connection, right? if this is the case are you sure that all your bolts are done up correctly and tightly and also im assuming you have a gasket. make sure it isnt cracked because your actions of sealing it could mean just that. another extreme possibility is that the surface in which you turbo and dump connects is not flat, have you checked that (highly doubtful that this is the case though)
https://www.sau.com.au/forums/topic/87101-exhaust-leak/#findComment-1573479
Basically what is happening is...because the parts are slightly moving...it comes loose from the turbo.
The first time it happened i replaced the gasket, and resealed it...
it doesnt leak for about 2 - 4 weeks, then starts getting worse and worse...
https://www.sau.com.au/forums/topic/87101-exhaust-leak/#findComment-1573614
That still doesn't quite clear it up. If nuts are coming loose and allowing the turbo to seperate from the dump that's quite different to just blowing the gasket. If its the nuts, are you torquing them to spec? If its the gasket the keeps blowing, its more likely you need the surfaces machined.
https://www.sau.com.au/forums/topic/87101-exhaust-leak/#findComment-1573903
You are certain that it is the xforce exhaust.
All flanges these days are lazer cut.
Are you sure that it's not an exh manifold stud or 2 broken.I ask because i had that problem and so have many others with gts-t's.
The only fix for that was an easy out drill bit and new exh mani studs.
https://www.sau.com.au/forums/topic/87101-exhaust-leak/#findComment-1577193
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
