Dont some of the EVO models have rear facing vents?
But vents in most applications vents are a joke and make automotive engineers laugh when goons with no idea put them in. Even many factory vents serve not purpose. In some cases exit vents in the bonnet will reduce airflow around critical areas such as the oil filter, sump, front diff and oil cooler. Raising the rear of the bonnet is just as bad the air will flow through the radiator then up across the top of the engine and out the back. It will not flow over the exhaust manifolds, turbo, oil cooler, sump, diff and gear box.
  • Replies 42
Posted Images
even old SLR TORANAS have rear facing vents. well its a bonnet scoop really, but it faces backwards. need em for those fire breathing v8s but... not really.
a definitive answer on this topic would be great - on both what the ADR says, and about how effective/ineffective they are at keeping things cool. i figure if your cruising along slowly or parked in traffic a bit a rearward vent after the radiator would help, but if you are constantly hammering along at warp, maybe a fwd facing one, like the mighty rex has for its lil IC.
Was just told by a mate that it was proven that at speed air actually came out of the WRX scoop. There was a lot of air coming into the engine bay through tthe front of the car, creating positive pressure under the bonnet and had no where to go but out the scoop.................. dunno if it is true, but sounds plausable!
Plus wrx scoops are gay, I have seen them fitted on everything from a wr-excell to a stock corrolla.
Personally I would never get a forward facing scoop ever, but that is just me :P
well im not exactly going to be circuit racing and blowing hoses off my car so i have no qualms about throwing a bonnet on with a rearward facing scoop.
if the scoop sits after the radiator, before the front of the head, the only stuff that would come out is radiator fluid - which is not going to be much different than using your wiper washers as far as visibility goes. soon as i can GET one, im painting it, its on like donkey kong.
and Ska, i agree totally. seen one on an 89 laser. top that - should be a new thread - "crap we've seen wrx scoops on"
maybe its just the wording, but that made no sense to me whatsoever.
if the vent sits just after the radiator, the only fluid that could come out is from the radiator, which would be steam anyway (if its hot enough to build up pressure to blow of a pipe) which wouldnt be any more hazardous than wiper fluid, is my argument.
wow. cool. yet ANOTHER grey area. next time i get pulled over ill have to ask a cop. clear it up once and for all.
Asking a cop would probably prove to be the most unlikely, most unreliable way to figure out its legality.
The problem with that is that it'll be their interpretation of the rules (assuming they know them properly, and not all of them will) - so it might even depend on the mood that the particular cop is in on the day!
But regardless, here's hoping and best of luck getting a straight answer. Who knows, it might get us closer to an answer.
Nick T.
was in DMD image the other day to organise my kit and hit them up for details on a bonnet. They dont do stag bonnets, but can do me a fast and furious looking vented one for the paltry sum of 1500. they need to get one and make a mould off it. fantastic.
Don said if it were for more than one car, say two three or four, it would be considerably less. but i wouldnt want so many stags to have the same vented bonnet people will think its as standard as airbags.
thought about modifying my existing bonnet... dont know how fiberglass and metal would mix with that heat under it though. and suggestions or ideas or experiences or alternatives?
oh and dmd didnt have a WRX in site, let alone a scoop. love it. nissan central. few tricked out hondas...
<_< and terminal - your clear indicators go alright too...
Edited by qikstagea
lol i gave u a definitive answer - you cant have aftermarket rearward facing vents - well they can be rearward facing but CANT HAVE AN OPENING if they face backwards (only for looks is ok).
Here ya go:
An air scoop fitted to the bonnet of a vehicle must not intrude into the line of sight. An air scoop must not have an unobstructed rearward facing opening (an incident such as the bursting of a radiator hose could result in the windscreen becoming completely obscured). The maximum air scoop protection should not exceed 60 mm
Ive got a copy of the bit from the ADRs and licensing technical guidelines that says it. Even with front facing vents there's a load of guidelines and restrictions. Heres the scan of the front facing vent requirements too:
And line of sight in relation to vents:
so that covers scoops sitting OUT of the bonnet, but not vents that are cut into the bonnet. you read everything in this thread? doesnt seem too difinitive. what does "unobscured" entail> so if its a vent with mesh, its okay? see what i mean? and then theres the herrod rearward vent, among others. there are obviously ways around it, brazen.
dont be so quick to bend over for the government, champ. if you can register a car with a quad supercharged 26 litre engine (that, by the way, has a rearward facing scoop), im sure you can manage a vent in your bonnet.
oh dear... "unobstructed" means it cant get through (any liquid escape) - so mesh doesnt apply - pretty straight forward that one. The OUT of the bonet is just showing you max heights etc for line of sight... it still applies for vents INTO the bonnet - cant face rearward. You'll also note I said "aftermarket" - some pre-new-car-handover ADR approvals have been given (eg Herrod). So no I dont see what u mean - pretty straight forward to me after spending ages down the Technical Division reading through the ADRs and other guideliens with the Technical Manager over here in WA.... and yeah - as said in previous threads - maybe different over east - but normally things are MORE restrictive over there thna here in teh West. Its all just whether you'll get picked up though as to taking the risk - up to you - same thing with replacement front and rear bumpers - not allowed technically (can only have lip spoilers) - but peopel sell full front and rear bumpers for lancers and all sorts of shit - technically illegal - but hey never seen a lancer yellowed for the ricey bumpers though.
    • After @Kinkstaah debacle, I'd never want to try and get it right 😛
    • The hood lines up with the fenders. The front bar doesn't perfectly line up with the fenders where the wheel arch is. You have to 'squeeze' the front bar 'in' as it wants to naturally flare out and be longer on the sides. There's a few threads where people notice this when they only swap a GTR style bumper and front bar. Unless you have genuine OEM items - you may be better served getting conversion kits. There are GTT bumpers to fit GTR hoods. There are GTR hoods (non genuine) to fit the GTT bracketry. MAY
    • The real question is, on some of those wild roads they call highways, how many times did a farmer in an old ute from the early 2000s blaze past you over double lines?   Tassie is a wild and really cool place, and after doing a work related road trip there January of 24, I understand why Targa Tasmania is ran there, and is so tough to do well at! We had a brand new Camry Hybrid that handled quite nicely, and thankfully weren't in an old car, because cresting some of those hills in a 100kmh zone for it to suddenly be like "surprise f**kers, this is a recommended 30kmh hard right turn" wouldn't be pretty. We weren't racing the Camry around, but we weren't slouching in the bends either. But my lord those old farmers know their old clapped out utes, and those roads, as they were absolutely hammering it!   You're also super lucky to make it up to Mt Wellingtong this time of year. It's often road closed with snow/ice! Also, I hope you hit up Salamander Road in Hobart for some insanely good food (I highly recommend the dimly lit Irish pub for a Guiness Pie, or even the bangers and mash!!!)   How long did the Ferry take to get across? I want to do a road trip of Tas on my own time, but I get horrifically sea sick, and I don't want me on the Ferry, just the car 😛
    • So far so good, about 30km on it so far and nothing out of sorts yet thankfully
    • Look at @Kinkstaah's thread on the issue.
