try terry from www.kansaiautomotive.com i know he is always getting parts from japan and know he's also brought a few cima's into AUS...
either email him or his name is 'savalas' on nissansilvia.com (pm him)
Thanks guys, please keep all the good info comming.
Cheers
Danny :(
https://www.sau.com.au/forums/topic/87252-cima/#findComment-1576901
cima's share a lot of common parts with locally sold Maxima's. If you're after spare parts its a good bet you'll find a alternative locally.
Or are you after aftermarket parts for em?
https://www.sau.com.au/forums/topic/87252-cima/#findComment-1576993
First thanks for the help, second, Iam after the castor rods and cv boots (which are split), I am also after the ball joints (left and right). I dont know if these are aftermaket, but if I can find some nice goodies, it is always nice to know where there are. So the running gear of the Maxima is sister to the Cima, which model??
Anyway, hope to hear whatever you have to offer.
Cheers
Danny B)
https://www.sau.com.au/forums/topic/87252-cima/#findComment-1581527
  • 1 year later...
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
