Hi lads,
There's a particular R33 gtst S2 that im lookin at getting .. its nice and clean and looks to be in good condition, and most of all its as stock as they come which is what im after.
Everything about the car meets what im after, however the "gt25t" sticker on the back is missing .. Usually something like that wouldn't particularly bother me, but I sorta came to the conclusion that it might mean that the car has had a respray.
For the record, the car is a 1996 model, and is painted in black. Are there any good/tricky ways to tell if its had a respray or not? or is this a fair indication?
I guess the real question is, how concerned should I be if it *has* had a respray ? :D
https://www.sau.com.au/forums/topic/87402-question-about-respray/
Hi lads,
I guess the real question is, how concerned should I be if it *has* had a respray ?  :(
where abouts is the car from?
and panel beaters/spray shops can tell if it has a thicker/thinner coat of paint than factory...
located at a dealer (in QLD).. havent seen the car yet, only pics .. all looks well from what I can derrive from the photos.
Are there (m)any skylines that would have come into the country without the "gt25t" sticker? My only thoughts are that if the car is lacking that sticker, its probably had a respray either because the paint was nasty, or its taken some damage.
I dunno if it helps, but, here's a pic ..
Edited by knifebunny
My S2 doesn't have the sticker.
If you say it's S2, it's a bit suspicious because the "SKYLINE" garnish on the rear is clear - on S2 cars it is meant to be the same colour as the body.
Fastest way to find clear things up is goto the Nissan FAST thread ( http://www.skylinesaustralia.com/forums/in...showtopic=44182 ) and post up the VIN number - that was people can find out the original colour code and date of manufacture of the vehicle.
or just put the VIN here and ill do it for you
i was gonna say the same about the skyline garnish at the back...unless its 1 of those 40th anniversary 1's...i saw a white 1 for sale which was like 96 or 97 model, and it had clear like the series 1's .
also, maybe the sticker was just taken off....if its just a sticker, then its not hard to take off, and a lot of people like the clean look
that's wierd coz i used to have an S1 that was teh same color as the body..
Hi lads,
I guess the real question is, how concerned should I be if it *has* had a respray ?  :)
hey, i would not say that is a fair indication. u need someone who knows what to look for to see the car in person.
i have seen many gts-ts in the past 2 years, and at least 8 out of 10 have had a full respray or had lots of the car painted.
its not really a worry its just up to u when it comes to how good the paintjob is. u wont find one with original paint so in case u were thinking that most have original paint, they dont.
so basically dont worry. but dont buy without seeing in person, it could have all sorts of things wrong with it.
also the skyline panel may light up at night (factory rare option) so ask the seller if it does. if it does not it is either broken, or it has been replaced with a series one part.
Edited by siksII
actually, thats interesting... "gts25t" is just a sticker, yet so many r33's are debadged at the rear. You can understand that people would flog the "GT" badge on the other side, but the sticker?? ...maybe r33 owners just dont like it & take it off or something? Mine still has the sticker, and i've never considered taking it off... i like to proudly advertise the skyline name :D
Edited by Mickroy
haha @ thinking it's an n/a
now that i have noticed it on this particular ride, i've seen quite a few others cruising around without it .. it seems to be more common than I thought.
Seems to be one of those nit-picky things you only seem to pickup on when you're genuinely interested in making a purchase :D
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
