Fri 14&29th Oct Drive Day, At The Creek $120
All,
If you want to do a track day at Eastern Creek, this is the cheapest option since Moto Concepts were kicked out. It’s a Private practice day run by the ARDC, you will need a L2S or C3 licence to attend.
There are actually 2 days.
Friday the 14th Oct 05 and 29th Oct 05
Details can be found at
http://www.eastern-creek-raceway.com/ Click on Private Practice.
Cost $120 for the Day!
You will need to be an SAU Member and part with $80 bucks for a CAMS L2S licence if you dont already have a CAMS licence.
If you want tickets to the V8's then become a member of the ARDC ($150) and the cost becomes $80 for the day!
Normal non flammable head to toe cloths and a Helmet will get you in, and a road worthy car, they do check them!
These guys run the day very much like a race meet so they can waist a little bit of time being pedantic, but its always good value. With only Cars and L2S they are likely to run alternate 20 or 30 min sessions all day.
Im going to the Friday and Maybe then again on the next one.
Abo was keen as well.
Please let me know if you want to come, and I will contact the creek to let them know the numbers. No need for deposits or anything, you can arrive on the day but they do ask you let them know so they can balance numbers. Please dont commit unless you are 100% coming, no keyboard warriors, I dont want to advise the ADRC we are coming with 15 cars and only have 5 turn up. If you commit, the only excuse I will accept is a dead car or family member.
I will continue to update this post with names.
14th Oct 05
Oz GTR - R34 GTR
azzr32 - R32 GT
voqi000 - GTS
Zane - R33 GTS
Beer Baron - GTR
29th Oct 05
Neil
Thanks
Edited by Oz GTR02V
  • Replies 134
For this and all other questions it may be best to call them direct 96721000, but I thought I saw other cars with slicks last time I was out there, perhaps they were semi?
azzr32, see you there, your on the list.
vogi000, Contact Dunkan or one of the other committee members. It takes 2 weeks for your book to come through, but you can drive on the day with a receipt.
just one thing to check is that these two dates are not C3 only days. quite a few of the car practice sessions are reseved for C3 (now PC) licence holders only. there are L2S ones too though.
I may be up for it, but i'll let you know when i am certain. Should be a nice day out providing it's not too hot by then. We raced at EC on the weekend and on the saturday it was very hot already! :D
You don't really need to confirm the spot although I think Paul will be letting them know. They don't enforce limits on the number of cars at these days so you wont miss out.
Re the license Adam can give you one on the day if you are an SAU club member. Otherwise go to the CAMS site ASAP, download and send back the license application form for L2S
I'm just trying to figure it out.
The form on the website is sent directly to CAMS, there's no facility for the club issued licences on it, and no need for a club rep to fill anything out.
The forms CAMS sends to the club have the "Temporary" slip on them.
When you rock up to one of these days, or any CAMS sanctioned event, as a competitor they should ask for both your CAMS Licence and your club membership card ( to show you are a member of a CAMS affiliated club).
    • Was that with the cas upside or correct way up?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
