What comes in the kit? flyn seen the ad on n.s have gtr-s for $2500 if you really want one. Any bolt on job turbo shouldnt require any stuffing around ie welding.
The ones of horse power in a box use your standard turbo for the rear housing (I think) or a rb25 housing or vg30 so it should be a bolt on job.
At the end of the day what power level do you want? no point spending 3 grand if you dont have to.
Oh hey fast fours has a r33 in it with a gtr-s its making 301 rwkw on 1.4 bar I'll give them my asshat if that it was made on pump fuel though
I don't know how the SR20 compares to the RB20 as far as power output goes, but I currently have an HKS GT-RS turbo on my SR20 making 250rwkw. Boost is 1.2bar, 260/12mm cams, PowerFC D-Jetro, port and polished head, 1.1mm headgasket for 8.8:1 compression.
arent you in japan though ? jap fuel/octane ? ;)
most of the guys here in aus struggle to get 240rwkw out of a GTRS on an sr20, general consensus is that the turbine is too small and gets choked up in the high rpm's.
without cams, an sr20 will struggle to pull 220rwkw from the various dyno results ive seen
also it seems that rb20's lack the same down low an sr20 has, so the GTRS would be even laggier, if you guys consider a 2530 laggy on an rb20...
i was told the GTRs will be less laggy than the 2530
This is the reply i got from horsepowerinabox "We do a RB style Garrett GT28RS that uses an original RB Nissan Exhaust
housing to retain the TY3 flange and 6 bolt dump. These units are $1850
delivered, and we also offer an oil/water kit in braided for $280."
is this the GTRs? or some sort of version of it?
my car is auto and i want around 300hp as pritty much that as far as you can go with the stock engine internals.
I'd say the gt28rs is similar to gtrs but its not the same turbo probably just a similar Garretts version I'd ask if your stock water/oil metal lines will fit up or if you need the braided lines if not dont bother getting them you. Did you tell horsepowerinabox that you only want 300hp? the gt28rs I found was a 350hp version?
oh yeah with the kits for the GTRS for 2700 apparently it is everything you need they just said it may be a bit more or bit less depending on exchange rate. so around 300 extra to fit and they said at most it should be 2800 for the turbo kit. so for the extra 300 for them to dyno it before and after and set to safe boost iwth injectors doesn't seem to bad.
i dono wat 1900 us dollars is though how do you convert it?
gt28rs would be garretts answer to hks 2510-2530 it will do 200-220 rwkw so 300ish hp atw u did want 300 at the wheels right so 400ish hp at the engine?. Find out if you need the braided line kit or if your stock lines will fit up if the stock lines will fit dont bother buying the kit. Also have a look at the ebay turbo thread as the prices seem very good
yeah 300 at the wheels. Yeah ill find out about oil and water lines but i doubt they are the same. So that turbo would bolts straight onto my exisiting dump pipe manifold and intake pipe?
by the sounds of it that turbo would be enough for the sorta power i am after and a lot cheaper, i just don't want to run into trouble with the install
Ive got stuff before from him he seemed ok when I spoke to him. Spell it out to him that you want to bolt it on your self hmm guess it's bit hard when he's not answering you though.
found this for you on NS maybe go this way similar price
http://www.nissansilvia.com/forums/index.p...howtopic=112264
"i shouold be able to get similar kw;s do you. you recon?"
with a gtrs you should easily reach the same power figure as me probably more. I have get a FCD soon though I was hitting the fuel cut on the way home as it was a bit cold and the boost was spiking to 1 bar
    • Yeah, it's getting like that, my daughter is coming over on Thursday to help me remove the bonnet so I can install the Carbuilders underbonnet stuff,  I might get her to give me a hand and remove the hardtop, maybe, because on really hot days the detachable hardtop helps the aircon keep the interior cool, the heat just punches straight through to rag top I also don't have enough hair for the "wind in the hair" experience, so there is that....LOL
    • Could be falling edge/rising edge is set wrong. Are you getting sync errors?
    • On BMWs what I do because I'm more confident that I can't instantly crush the pinch welds and do thousands of USD in chassis damage is use a set of rubber jacking pads designed to protect the chassis/plastic adapter and raise a corner of the car, place the aforementioned 2x12 inch wooden planks under a tire, drop the car, then this normally gives me enough clearance to get to the front central jack point. If you don't need it to be a ramp it only needs to be 1-1.5 feet long. On my R33 I do not trust the pinch welds to tolerate any of this so I drive up on the ramps. Before then when I had to get a new floor jack that no longer cleared the front lip I removed it to get enough clearance to put the jack under it. Once you're on the ramps once you simply never let the car down to the ground. It lives on the ramps or on jack stands.
