  • Replies 101
As far as I know all you need to run is a helmet, long pants and sleeves and closed shoes! (I prefer my thongs) But you can still go there and spectate...theres pretty big crowds and after a night of listening to some of those rota's roar your gonna be pratically deaf in both ears but what the heck!!!
I'm gonna try my best to find someone to take me...After 2 days on this board it looks like ill get to put a few faces to some of these members!!
i should be there, most probably spectating though, but if im keen enough ill join all yous in an off street drag in my 180sx, i should have it by then no worries......my importer said next wedensday its yours.
what time were you pulling?
I had two passes which were pretty ordinary. 13.2 ET with 2.1 60FT (I know I know....)........I don't think I'll have any more mods in the car by then so I hope to run a 12 in current trim.
As long as I line up VISHES I'll be happy BWHAHA =)
Well, if skylines are taking over the drags from the 5L boys, I better come along and give a hand.
Don't forget to get there early. It takes ages to get your first run if you arrive after 5....
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
