Item:t4 turbo
Item Condition:Brand new, never fitted
Reason for Selling:cant afford to fit. need** a t3 turbo instead.
Price and Payment Conditions:$1200 ono pick up or can send interstate
Extra Info:ar .60
Contact Details:[email protected]
pics
Edited by gwaping2k
https://www.sau.com.au/forums/topic/87576-garrett-big-t4-turbo/
I am willing to swap with vgc used GT2530 with T3 flange or something similar. I need a direct bolt on. Obviously i cant afford to spend anymore money to custom fit this T4.
cheers guys :P
heres another pic
This is a genuine garrett turbocharger, not some cheap immitation!
Any offers will be considered :D cmon ppl dont be shy, i may even interested with a apexi power fc with controller! anything with the same value as my turbo :rolleyes:
hey does that mean that this turbo does not need anything. like what i mean is that it has all the parts i need to put it straight onto a gts non turbo??? or do i need more stuff.
mate u need more than just the above turbo to fit this in....since your car is non turbo, you will need a manifold,wastegate,intercooler etc....
So the answer is NO this is not a straight bolt on to a NON TURBO sky :)
pm replied :(
any other offers??? cmon ppl, this is a good deal, wont be disappointed.
only if i have money to bolt this in :unsure:
Edited by gwaping2k
out of curiosity is this a turbo that comes stock wit r33 cos i want to upgrade the turbo on a r31 rb20det but just to a stock 33 turbo cos i have heard that the rb20 turbo (t3 i think) cant handle more than 8 psi safely but the 33 turbo can handle 1bar and is worth the conversion btw if it inst the stock 33 turbo what is the name of the 33 turbo
thanks for the help
thanks for the help
Hi Mate, i dont really know much about RB20 turbo, but the R33 turbo has the same flange as the RB20 which is t3...(as far as i know) i dont know what the r33 stock turbo is called, but its a t3 type with .ar50 on compressor, not sure about the exhaust housing (try searching the forum in regards to that) My stock turbo will be on sale once i get a t3 turbo replacement for this garrett, as i simply wants a bolt on job.
ScarifieR32- My mech told me it will not be too laggy, it will boost from 3500rpm or 4000rpm from usually approx 2200 rpm(from my stock turbo) i would put this in my r33 if i have the extra money to buy manifold, wastegate,vband etc..but i dont ;)
thanks heaps can ur 33 turbo hold a bar of boost safely cos thats all i really want
when u r selling it let me no thanks
hi mate, my turbo is only boosted to 12psi, no higher.
Any takers at all? new price now $950!
cmon ppl, this is cheap ass :O
exactly...lag city mate...i got a .84 rear housing on mine and its on a rb25..full boost doenst kick in till 5200rpm... and yours is bigger..so i would think like no boost in first gear lol.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
