been searching around looking at all the hicas issues, none seem to be the same as mine although probably have the same soloution.
when im driving at 50km/h or so and jump on it the 4WS kicks in and the rears send me me in an awkward direction but the hicas light doesnt come on.
now this has only started happening since the aftermarket steering wheel.
im trying to get around this without a lock bar.
now 1 more point....
the original hicas plug has 2 contact point behind the original that it plugs into but i only have one plugged in, is it as simple as connecting the other contact??
any thoughts
thanks
any thoughts
thanks
someone i know had exact same thing happen but they had the hicas light come on also. if you don't have a proper hicas type boss kit then either buy one and fit or a proffessional or cluey person may be able to rig it up so it works..... it is the boss and wire/sensor thingys that would be causing the issue.
I had exactly the same problem.
my solution was to unplug it.
there are 2 plugs for the hicas.
they are under the parcel tray.
when you disconnect one, the light stays on..
you don't want that one.
disconnect the other one and HICAS no longer works and you don't go wobbling all over the place.
people told me over and over that this is not right and it won't stay in one place and shit.
but it did.
if you go in the boot, if I recall, the plugs are closer to the right speaker..
your problem is that it's not the correct boss for your car. some have the sensor 'lugs' in the 12 and 6 position some have them in the 2 and 7 position. have a look at your factory wheel and see which one you have. hicas light should not come on at all if it's working properly.
thats what i wanted to know!!
thanks mate ill check it out tonight!!
What year is your car? Its most likely meant to have the lugs at 2 and 8 or there abouts. If its a later model (late-92/93 through 94) it may have them at 12 and 6.
But as Richard said, the best way is to grab the OEM wheel and lineup the dot on the wheel with the dot on the spline and see where the lugs are meant to fit.
its a 93
has got the leather wheel like a gtr
i didnt notice any dots
and what spline??
There should be a dot on the steering wheel where it joins the column, and a dot on the end of the the steering shaft/spline (close to the edge) that emerges from the column (and that the wheel attaches too). Obviously you line the two dots up and rotate the HICAS prongs so they fall into the holes on the wheel.
Does that make sense (sorry, tired, not explain well :blink:).
k now i get it
i fiddled with the hicas prongs before i put the wheel on
ill take a closer look tonight
thanks for the info!
managed to fix it, thanks for those tips lwells!!
basically did what u said, took it off aligned the stocker back up, then put the bosskit on then the steering wheel...
did 100km last night....no wobble....no light
thanks
thanks
No worries. Nice to see its sorted :( Out of interest, were the HICAS prongs meant to be at 12 and 6 or 2 and 8?
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
