FOLLOWING PARTS ARE AVAILABLE OFF R32 GTE 4-Door
PRICES ARE NEGOTIABLE - ESPECIALLY ON BULK PURCHASES
Doors - $150ea
Door Glass - $50ea
Electric Window Regulators - $75ea
OR Complete Doors - $220
Other Door Window Controls - $25ea
Automatic Console - $100
Glove Box - $80
Front Seats - $150/pr
Rear Seat - $100
Complete Lock Set (Ignition,Doors,Boot) - $100
Steering Column & Standard Steering Wheel - $75
"A" Pillar Trims - $25ea
"B" Pillar Trims (Upper and Lower) $50 a side
Carpet - $50
Front Courtest Light - $50
Rear View Mirror - $20
Side Mirrors - $50ea
Scuff Plates - $60/set
Kick Panel Trims - $10 ea
[/b]
Brake Pedal Assy - $40
Coil Packs and Coil Pack Loom - $200
Dashboard - $75
Fuel Pump - $50
Accelerator Pedal Assy - $40
Radiator - $110
Wiper Motor - $40
Overflow Bottle - $25
Windscreen Washer Bottle $25
RB20DE Ecu - $40
Tailshaft - $50
Front Bumper Bar Reinforcement - $100
Front Bumper Bar - $100
Bonnet - $150
Front Guards - $80 Ea
Head Lights - $145 Ea
LH Tail-Light - 4-Door - $150
GT Guard Badges - $15 ea
CA Silvia Rims - $150/set
2.5" Cat Back Exhaust W/- Cannon - Almost New - $300
Other Parts Available, Please Enquire
Edited by homlie
https://www.sau.com.au/forums/topic/88128-r32-parts/
  • Replies 86
Posted Images
