FOLLOWING PARTS ARE AVAILABLE OFF R32 GTE 4-Door
PRICES ARE NEGOTIABLE - ESPECIALLY ON BULK PURCHASES
Doors - $150ea
Door Glass - $50ea
Electric Window Regulators - $75ea
OR Complete Doors - $220
Other Door Window Controls - $25ea
Automatic Console - $100
Glove Box - $80
Front Seats - $150/pr
Rear Seat - $100
Complete Lock Set (Ignition,Doors,Boot) - $100
Steering Column & Standard Steering Wheel - $75
"A" Pillar Trims - $25ea
"B" Pillar Trims (Upper and Lower) $50 a side
Carpet - $50
Front Courtest Light - $50
Rear View Mirror - $20
Side Mirrors - $50ea
Scuff Plates - $60/set
Kick Panel Trims - $10 ea
[/b]
Brake Pedal Assy - $40
Coil Packs and Coil Pack Loom - $200
Dashboard - $75
Fuel Pump - $50
Accelerator Pedal Assy - $40
Radiator - $110
Wiper Motor - $40
Overflow Bottle - $25
Windscreen Washer Bottle $25
RB20DE Ecu - $40
Tailshaft - $50
Front Bumper Bar Reinforcement - $100
Front Bumper Bar - $100
Bonnet - $150
Front Guards - $80 Ea
Head Lights - $145 Ea
LH Tail-Light - 4-Door - $150
GT Guard Badges - $15 ea
CA Silvia Rims - $150/set
2.5" Cat Back Exhaust W/- Cannon - Almost New - $300
Other Parts Available, Please Enquire
Edited by homlie
https://www.sau.com.au/forums/topic/88128-r32-parts/
  • Replies 86
Posted Images
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
