  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
u guys work in it?
hmmmmmmm
you guys can hook me up hehehehee :)
is thornlie a hairdressing campus?
ahhhh
i retract my previous statement if i put 15 grand of smoothtalk into it i shall get my free haircuts i get free ones anyways all i gotta do is shave my head at home
adrian
Originally posted by GTS-t VSPEC
Lucky bastard, I hope someone dies and gives me money. I'll help you spend it, the car could be very fast soon.
See'ya:burnout:
Nice to see the family sentiment is alive and well. When you go to family do's are you sitting there thinking if he / she croaks here comes my new front mount etc:p
coarse not!! My love of imports started with an 88 black targa 300zx Turbs best condition in perth - still got it trying to sell the little bugger. My dad was pointing at the Z32 in the auto trader going "U like that?" and im like awww shore do and then he would go "you cant have it its too expensive!" then when he pointed out the Z31 (cos it looks pretty hot not like the others u see around" ) i thought he was pulling the same trick. It was traded in by some 60yr old guy who bought it out from hong kong and bought a black R33 GTST like what i now have concidently he was at the car yard when i picked up my GTST small world.
Geez , my first car was a Datto 1600.
Wish I still had it sometimes but that was a looooong time ago.
Cheers
Ken
btw has the Z31 got a heater ? Strange question I know but have seen a LOT of Hong Kong cars with only aircon , no heater?
yes it has a heater - haha and it stays on!! You fry in a black targa with a heater thats just wont quit!!
Well when i was 16 i was a lil junior working at skippers and i was walking down shepperton rd and thought - when i get my license im going to have a black car with attitude.
I have a dream :) haha
Despite my mum telling me from a young age that my first car wouldnt be a V6 or V8 i could put that outta my head but thank heavens for dad i had a V6 turbo and learnt to drive mainly on a HSV. With a family like mine u have to be into cars theres no way around it.
Jeez Ken, your really showing your age with the Datto 1600, did you get it when they first started producing them:lol:
We're lucky these days, most of us are able to buy cars that our parents would have dreamed about.
I have let my dad drive the car once, unfortunately he didn't die. I have to wait for both my parents to croak, and then find a way to kill my sister, not that any of this is premediated:lol:
See'ya:burnout:
Originally posted by Pva_Glue
heheheh  Datto 1600...  what's that?!?!
is it like small mini?
hahah
Joe , wash your mouth out, comparing that pommy front wheel drive , engine the wrong way shoebox on wheels with the finest engine the right way , rear wheel drive rally car to come out of Japan in the 70's .
Cheers
( those were the days )
Ken
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
