  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
I couldn't warrant a new thread so I thought I would just post here instead..... I'm excited as I have just ordered my HKS cooler and Apexi AVC-R from Nengun... :)
Hehe in a few weeks I should be moving along very nicely :burnout: ... Can't wait for the next croose so I can meet up and see some of these cars you are talking about!!! :uh-huh:
Brett
Skyzerr, What suspension was it, Koni adjustables?
MrGTST, Nice way to spend a few K, should be worth it for the difference in performance. Hope it all goes smoothly. The next cruise is this Sunday, and then one the following week. Hope to see you there.
See'ya:burnout:
I believe the 255x40x17 refers to:
255 - Width in "mm" of the tyre
40 - The profile of the tyre. I.E the smaller the number the thinner the tire is.. I hope that makes sense
17 - The size of the rim in inchs
I hope that makes sense :(
Skyzerr, sorry about that dude, I was trying to reverse park the car, and pressed a little too hand on the phone. Couldn't ring you back cause I have no money left on the phone. Sorry.
rev, those widths seem a bit optimistic, 9" rims need at least 255's to fit, preferable 265's.
Macka brought the baby oil and I brought the whip, was a good bonding session.:lol:
See'ya:burnout:
