  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
rev, those widths seem a bit optimistic, 9" rims need at least 255's to fit, preferable 265's.
See'ya:burnout:
Do the math. How many mm to one inch?
Match tyre width to rim width give or take 1 inch max, for handling.
rev,
I have 8" rims and 9" rims, I know what fits on them well. No-one wants a tyre that has to be stretched over the rim, it looks shit, and handles badly.
Adrian,
Yes we have camera's, so I suggest you leave that dog alone.
MrGTST,
Your meant to post the chicken noise. Tyr it again, the rules are simple.
See'ya:burnout:
hmmmm
as a expert nandos chicken griller
i should get this one easy!
Cluck Cluck
Bwark Bwark Bwark
(flapping of feathers)
ahhh easy does it
mr gts-t answered for ya by a true professional
anyone up for a drive tonight
i am bored nuthin to do!
adrian :)
rev,
See'ya:burnout:
Want your sidewalls to be straight without any radial roll?
Ah.. I see you want it to 'look good';)
say no-more!
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
