  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mmmmmmmm
mackas car had a horrid two days then?
man i feel sorry for the guy
oh well she'll be right
porn movies hey?
i think there looking for guys to star in some beastiality porns?
you interested? too late i already put your name down for the scene where you have to bust a lady monkey open and at the same time let a eel slither all over you!
good
i knew you would love it! :D
adrian :P
ahaaha dammmit
after i posted that i realised
i just put myself out as a "don't leave home, postwhore, who has a explicit and wierd imagination"
oh well
it's all good
so u did go to the audition?
and it went great?
awesome is it an electric eel?
always wanted to see one of them?
just makes sure i don't touch it ewww it has paul germs!
hehehe
adrian :D
Originally posted by GTS-t VSPEC
Adrian,
I only want to star in Porn movies, so far I haven't had any auditions:lol:
Tuning Macka's car was a bit of a nightmare, lots of minor issues making life tough.
See'ya:burnout:
The only thing that was tough for you was when i handed u the timing light :D :lol:
    • Make sure you use the spherical bushes** on the lower arms, ifyou do that. ** at least, if not the whole replacement lower arm.
    • The tap for coolant flow control will be stuck open. It's not just the air door motor that dies.
    • Not really, but the heater box is pretty simple mechanically....if the door is one way the air bypasses the heater core and if it is the other way it goes through it for warm air.  If you are sure the actuator you moved manually is for the heater mix (there would also be one for output air direction) then I'd take the heater box out and see what is happening (you'll have to regass and re-coolant the systems afterwards) BTW pp724 onwards from the GTR workshop manual cover the system in good detail, it is probably worth checking. I think the IAT sensor might be a problem electrically for getting cold (if you got 24 error code not -24 it thinks the incoming air is -50c) and it covers how to test the sensor (although most likely it is either not plugged in or a wire is damaged)
    • Use the GKTech subframe bush and bring your subframe 10mm closer to the chassis. You'll need to fix an exhaust hanger to suit. One of the best mods I've done.
    • You'd really have to pull it apart further to know, it least you can be confident that the one heading to the back is not connected any more. There was once a ground on the shifter seal mount too, your head unit issue could be that simple
