  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
sup guys
long long long time no chat
did yas missme?
well i missed out on a good cruise
coz i nearly got arrested last night, only got home at 5am in the morning and woke up at 11am
i was pist that i missed this cruise dammit!
sorry to hear the unfortunate accident, recalls memomries of how i got hit from behind! arggggggggggggggh
paul whered u got ur new bits of pipe dun? hehehehehee naughty boy
adrian :D
