  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Doesn't my post prove it???? Never delete picture messages sent to you... you never know when they will come in handy. :D
Had someone asked you yesterday if you thought tomorrow you would be talking about Penis doorknockers you would probably said no... :) .... Just imagine what we will talk about tomorrow!!!
ohhh believe me.... there are no boundaries I am aware of in the gutter.... I have been right down there before.... nice place to visit but wouldnt want to live there :D
at this rate you should have your 50 ppd in a week or two... are you going to throw a celebration party???
I still live at home with my parents.... My "bedroom" actually used to be our games room with is detatched from the house out the back. Thats why it has the bar and pool table and such....
Hehe... You should see the looks on people faces when I tell them I have a bar in my bedroom!!!!
    • Thanks GTSboy. I will inspect the valves actually, is this something I can do while they are still in the head? The block/bores don’t look bad to be honest hey, I can still see the cross hatches in the bores and they still measure 86.5mm. I’m not sure how to measure the installed ring gaps but I will do that and take it to someone who can.
    • I’ve had the same headache with my lowered car, scissor jack first then floor jack every time. Ended up grabbing an extra-low profile aluminum jack (about 70mm entry height) and it finally slides under the lip without drama.
    • No sync errors , i have installed AEM disk will return original 360 slot disk and check if there’s any one with running AEM disk could share setup
    • Its been a while! Finally thought to do something on this car, so here we go. This will be a slow burning, multiple posts as I spend 0.5-1hr a day on this job, over multiple days... Full set of GKTech suspension arms!   Step 1: Buy Arms, done! Step 2: Start removing stuff. HICAS was easy. Rear suspension arms are now gone, they were a bitch but breaker bars with long handle extensions, 2 1.5hr slots later, stock arms are off! Next step, remove the hubs and take them to work to press out the bearings and bushings!
