Hehehe , yea the subarus are a little weak in the gearbox area if mistreated ( ie. 6K clutch dumps )
The customers get upset when you tell there 3rd mod after a 3in pipe and clutch is a gearbox kit to make the rest of there mods stay together.
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
STI gearkits are stronger than stock and after that you start looking at dog gears , be it a full kit or just 1, 2 and 3.
PPG do a reasonably priced kit.
They do a dog kit for a GTR at $6300 plus forks $800 plus install.
Hmmmmm.
btw manifold is still leaking but will pull apart next week .
Bit of time b4 next comp day ( not like the 1 week gap this time:mad:
Cheers
Ken
Originally posted by GTS-t VSPEC
Yeah, I didn't realise this round was so soon.
Will you be going to the night master or the 4,6 and rotary?
I hope my Rb25 box will hold, can get expensive when you have to replace things like that.
See'ya:burnout:
will be flat out prepping 3 rally cars for end of March so doubt it.
Cheers and night
Ken
Yeah pretty good night, started in perth, then northbridge, then ended up in joondalup, but made it home so thats the main thing, im surprised i can still type properly.
are they the trial ones????
i have genuine NISMO 400R ones one my 'line and they have the little mesh bit towards the back end, but to tell ya the truth i wasnt really looking at skirts, cause i had them already, but there pretty good at WORKS so just pop in there and take a look im sure they will be able to sort out some good skirts for ya
troo troo
coz i saw some awesome skirts there last time
can't remember if it was 400r or trial
had like a lil triangle bit vent that was meshed on em ah well
must pop in and have look!
ah nice eventful nite? but joondalup? what the hell is in joondalup?
adrian :D
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
