  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
awww ya mean someone else has got them well thats cool lucky i didnt go for that then - yeah there was a naughty betty boop one too haha but i thought nah u guys already think my minds far enough into the gutter.
