  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha we are pretty cas around my work - in fact my two bosses come to work in cargo pants and hawaiian shirts - very loud prints on them too haha. So sometimes when i cant be stuffed i just chuck on a denim skirt and a tee and thats me ready :D ahhh im going to miss that job.
hahahahahahaha :bahaha: funny as
That reminds me - when I was in bali - we went on a boat trip and this guy wearing tight blue bike pants walked right in front of me - penis at eye level. I cracked up and lent over to my friend and said "he was circumcised" hahaha It was like vacuum sealed penis
no its not too low i like it just the way it is - its just got shot suspension thats all one of the options was to put new springs in it but they would make the front end higher and i dont want it higher :D So new rubbers n shockies - itll all be sweet.
yes ive had enough of feeling like im in a rodeo everytime i go over a bump hopefully i havent pissed all my money away this weekend and have got enough to do it this week. Then i'll go get my $5 wheel alignment etc from diffs and it'll handle like a dream - well hopefully anyway.
    • If by axles you mean driveshafts, they're supposed to have play in them. They are not hard to recondition, it's just pulling apart the cv's, cleaning them and regreasing, fit new boots. I've only rebuilt one set and there was fk-all wear in them, still running just fine 8 years later.
    • Note, the aluminium bit that screws in the end that you have to remove to dismantle the rack is single use as it's punch-marked, it will strip when you unscrew it, and then you have to flatten the notch in the steel rack body, screw in a new aluminium end when rebuilding, then punch-mark it again once assembled. it is also 'somewhat tricky' to refit the rack>steering wheel linkage gear as it needs to be set to the right preloads etc. A rebuild is probably something that's better just given to a steering shop for a couple of hundred, unless you're mad-keen to do it yourself.
    • Do you have the workshop Manuel? Sorry that's a Spanish waiter...I mean, manual? Some relevant pages>
    • How much have you lowered?  I had 350Z springs in the rear and was able to pull the camber into factory spec with the factory arms on the rear, obviously the front ran negative camber as it isn't adjustable, but rotating the wheels regularly evened out the wear.
