Nah its got worse since then Joe - wanna feel it now - its absolutely awful. They havent been able to get the wheels off to have a look - they rung me with wheres your lock nut and im like in the cab somewhere have a look and they're nah nah cant do that - geez what do they think i keep in there, i mean my mum occasionally drives it so its not like ive got stuff in my car i dont want to share - anyway a day later found my lock nut sitting on the back seat the dickheads shouldve looked they wouldnt have to look far!!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
moral of the story is that i dont know what suspension is on it and its unclear what has to be done but apparently the rubber stoppie thingys have gone and new front shocks are also needed suspectedly. I had the bushes replaced not that long ago so they wont need to be done.
steak for dinner - been so long since ive had red meat!! just kinda sits in my stomach and feels yukky so i dont eat it - in fact these days i really dont eat dinner i just stop feeling hungry after 4. I have a weird body in one day i can just guts myself and eat n eat n eat and the next day i eat the tinest thing and feel sick. Its got so bad that in year 10 i didnt eat for about 2 weeks i was soo weak couldnt get out of bed - my parents thought i had an eating disorder and it was dilberate but it wasnt its just i couldnt eat - i was talking to a girl about 2 years later and she had the same thing but she actually went to hospital for it.
hahaha wanna hear something people seem to think is gross?
I can eat a whole tin of anchovies by themselves for a snack hehe i think they are yummy.
I was just thinking about caesar salad - and it brought my mind onto anchovies.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
    • Hi, i’m making Vag coil loom for rb25det, can anyone confirm the wire guage i’m using for power supply in diagram is enough for supply not too small for loom? For earth do i need to follow the same procedure or i can use only 16awg wire for all coil and their connecting wire following to the plug?
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
