Originally posted by Micko
Still can't figure out why the reference is out for base timing, but got the CAS at about midpoint which should ba around 20 degrees - no pinging as best we can tell.
Hopefully put the car on a dyno tomorrow to check a couple of things are normal & then if all is good I should be able to put the problems behind me
*crosses fingers*
yea , lets hope so .
Have you had the CAS in the same place before ?
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Makes me wonder whether there ever was a problem with the knock sensors - who knows as long as it stays away, I don't really care.
Must say I have learnt a lot about the car throughout this process, so that definately makes things worth while (kind of!).
Well there must have been a prob somewhere or it wouldn't have kept showing a code
Cheers
ken
Nizmo - I dont know either, I'm just repeating what other people have told me:)
Shaddup and listen.
Geez , a women comes on and Micko goes off the topic.
Remember , your married:D
Cheers
Ken
i tell ya theres some real crap on TV!! Mum hijacked the computer there wasnt much happening so i told her she was welcome too.
Bloody family - having to share - glad im an only child - with siblings it would be worse!!
    • So sadly the fuel pump etc was not it. The pump and filter is new and it is still cutting around 4000 rpm. A read something about ABS/TCS (engine is from stagea and ECU too so no TCS) and i dont know for 100% that my car has ABS. It has ABS "cube" in engine bay but i dont think it works(or at least from my braking experience). Can be something like that?  I will be driving the car next week to Nistune tuner to properly see what is wrong...
    • the Tomei LSD fluid with lsd kit. frustrated that it was shaking the car to crap and affecting everything else negatively, I pulled the diff last night, and removed the lsd carrier, could not find anything wrong, however it seem to be 100 locked up acceleration, and deacceleration, wondering if they sent me a 2 way not a 1.5??  either way I installed the stock open carrier back in place. test drove everything smooth as butter again. no shake, shutter, random, what felt like clutch slip and grab or drive shaft play, etc. something differently wrong in side the lsd. I might bother taking it apart (if possible) to figure out what's going on inside this carrier, as bought too long ago to return.  only draw back is its back to a one wheel wonder.
    • If there's oil in with the clutch, I hope it finds its way out even if that hole has a cover/grommet 😛 I don't want oil near my cars clutch! 😛 Interested to hear the answer about covering it, I'm assuming a bung for a gearbox from another car that has a grommet to suit.
