  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha or some spanking joe ;)
i know - ive had nothing to do all week at work sooo thats my excuse but i dont think its going to get any better because my new desk is more sheltered so i can surf the net without anyone noticing and also im not gonig to have people pester me all the time for cars, equipment stationary and shit soooo ive become one of u haha
nah im pretty pleasant except when i get stuck doing someone elses job like stationary - the lady goes away i have never had anything to do with it but suddenly it gets handed to me haha ive left her such a mess! But the pleasantries have paid off because the reason why i got my new job is because i went outta my way for my new boss helping him choose his next car - i went and borrowed drive cars off managers at dealerships etc just for him and helped out with colours and this is before i knew that i was going to need his help to keep me in a job - so if your pleasant it does pay off but trust me i have my days where i really just dont give a fark!
i can watch any sport other than cricket or tennis - too me the most boring sports around - hell i can even watch golf but give me cricket im asleep within 5 mins but the english side do have the occasional looker to perv at i guess haha
i go into an auto shop and i have the same guy ask me the times if it was my car -
Is that your car
Yes
Is that you car
um err yes mate!
Aghhhh accept it - i maybe a chick but i can drive a nice car and yes i do know what its capable of errrr the dipshits of the world!
im like a hawk i watch people so closely around my car - its very much the touch it and die attitude - i maybe sweet but i pull a very mean death glare haha - it was like when i first decided to buy the car ive got and i went back to the caryard to take a good long look at what i was buying and there were there 11yr olds on bikes around it going "thats going to be my car" im thinking i think not! but they were so close to it and im standing there going just take one step closer to that car boy and you can kiss goodbye to ever having children - im so protective of my car - must take my maternal instinct out on something i guess haha
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
