  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
No but I believe a couple of guys came from the Army over there with skid car experience and are working for DTEC
John Willmot is one I think
Cheers
Ken
I met John once or twice his name rings a bell the Army guys did it as a full time job we only sat in for our courses so the Navy troops had a Navy staff member there.
Originally posted by bully
i think i saw a video of that set up with the camrys once when we were look into contracting out driver training for the services
yea we were trying to pick up the forces when they were looking at Privitisation.
Unfortunately there were too many white shirts upstairs with too much to lose and too many hidden agendas.
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
I was impressed by the way Micko's handles, and yes I will buy a GTR, but probably not just yet. My appendage is bigger:p
See'ya:burnout:
Dude if you were impressed with the handling you wanna ride in one with a real driver at the helm - take a spare pair of jocks though:D
anyway , enough of the reminiscing and hanging shit ( and probably washing ) on pwptf 's appendage.
The bootlid would fit a complete load on.
His personal one would just hold a gstring and a very small peg
Cheers
weiners anyone ??
Ken
Bully/Ken,
Sounds like you've both done alot, makes my career seem kinda boring. Sit behind a desk and use a computer, I think I need a different job.
See'ya:burnout:
Thats what i do now but yer had a lot of fun in my younger days and still am. I think you guys have refreshed me i was begining to feel old till i got the Supra and found you guys
Cheers
weiners anyone ??
Ken
i think you are being overluy generous there Ken
ture everyone was trying to protect there own interests in the end its all gone to crap now i hear nothing but bad stories - a mate of mine is the contact manager for Navy Driver training in Melbourne he stops by for a beer whenever he flys in.
Yes , ain't that the truth.
We almost got the W A police to use them for training but some spanker SGT could see his job disappearing and canned it.
Govt f**ing dept's. Spent 1,000's on vids , professional resume's etal and in the end nothing has come of it after about 8yrs.
Got out cos I didn't need the head f*ck and the heart attack
Cheers
broke but happy
Ken
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
