  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
EPOCH,
Yes, next to a brothel, but even I am not that desparate, that's money I could spend on mods:p
Ken,
What pads do you recommend? *speaking to GTRKEN*
See'ya:burnout:
best roadbased pad ( ie good cold bite , kind to discs , reasonable wear , no or little fade ) would have to be Pagid rs4-2's ( blue ones ).
I have not tried too many but the pagids are good for me.
Ferodo 2500 or 3000 are also supposed to work.
Ultimately you get exactly what you pay for.
price for pagids are bout $400 an end.
Cheers
Ken
If I buy one, then I want a fully modded one, prefer with roll cage etc. Sometime next year i hope.
See'ya:burnout:
Cage will not be legal over here and watch the mods. Depending on what you want to do ( wanners ,ses , mc) some of the mods may not be legal.
I can get them but suppose Danny or Ray will help you there.
Cheers
Ken
At $400 I think I'll stick with cheapies:p
See'ya:burnout:
ahh well , thats why a more dedicated person will beat you.
Motor racing is hell expensive at every level and there will always be someone who will commit to the best.
Wanners is 75% car , 25% driver . A bad driver can win in a good car but the opposite will never happen.
Cheers
Ken
Morning Troy,
Vibration can be due to a unblanced flywheel, or the fact that the harmonic balancer needs to be adjusted for the lightened flywheel.
Bunny hopping is usually due to the clutch's pucks gripping and then slipping.
See'ya:burnout:
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
