  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by gtrken
ot
Troy is there any way as a mod to find out if someone who was banned is reposting under a different nick ??
Cheers
Ken
yep
point me to the suspect posts
are u referring to wizzard also now know as gtrjoe
so how do i get this harmonic thingy fixed.
it only happens at 1500-2000 rpm range, fine after that all the way to redline
which was rather silly using the pfc untuned, read first tiem the car has ever pinged.
Troy,
Yes it was silly thrashing the car on an untuned computer, but hopefully no harm done.
I'm not sure if the factory harmonic balancer has any adjustment in it, may be necessary to buy an aftermarket one. Speak to Ross, he should have a good idea.
See'ya:burnout:
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
