Originally posted by Strich9ine
popped the question!!!!! 3 years eh? daym, ive done the whole sleeping with random chicks thing... it's crap.... relationships are SO much better, but THREE years... whoa!
(guess i should shutup now as im the one thinkin of  house!!)
no kylie and i are only 2 years in april the 14th to be exact.
anyways i've been told a long engagement is fine so if that aint a hint i don't know what is
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Troy,
I didn't realise you had to pay rent, makes it a bit harder to save.
Kym,
I like your GF, but take it from someone whose 5years relationship failed, it's not a sure thing that it will last.
See'ya:burnout:
ahhh now we get some dirt
but like my ex were u about to propose when the relationship ended with u finding out she was cheating on u
and u lost 1500 on the engagement ring u had beig made up for her. well not really i managed to sell it to the jeweler for 1200.
Originally posted by Nizmo
why the hell would you want to get yourself in that much debt anyway
Think about this:
You sell your house, you MAKE money.
You sell your car, you LOSE money.
Always.
Don't think of a house/property investment as a debt. This one's an asset :D
you won't get stuck buying a place too far south.
Yeh, like rockingham!
p.s. my olds paid off thier first home loan in 12years. and the second one (this house) in 8 years...
we've been in rocko 9 years now... now that's what i call financial planning!
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
