  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by skyzerr33
oh a good memory the multimedia students
god there were some honies in that lot.
one of em was caught bonking the lecturer to get a pass mark
naughty naughty
Hmmm I never heard of that one!!!!!
But ohhh yeah there were some very very nice looking ladies doing that course.... many of us on several occasions came very close to swapping courses!!!! :P
so u work near langtrees paul?
u should do lunch at the broken hill hotel on thursday from 12-2 hehe
aghh the broken hill - used to get molested if i even tried to walk past there to get to the bank when i worked at skippers haha. dodgy lot.
Trust you to know when the topless barmaids n strippers are on troy :P
Yeah I know that lecturer very very well.... What we couldnt work out though is she was quite often in that little building across the road in the public carpark next to the Tafe... we never could work out what the deal was with her!!!
Yeah that sounds about right..... Those were the days.... I swear we must of played cards about 2 hours each day back then.... It was cool. Luckily I am one of those people that the information just soked in without a great deal of attention/effort :P
Hmm not a bad effort..... I would like to go and get another certification but the costs and my apparent lack of motivation are stopping me so far.... Perhaps a Cisco ( which can now be done at TAFE ) or a Novell certification... both of which we use at work... I don't know what sort of coverage Novell has in the marketplace these days but its what I use daily at work so I figure that would be the most usefull to me...
My career has gone off on a tangent though .... I did the computer systems diploma so 99% of my training is in computers which is where I started in my job.... then after some redundancies I also inherited the RF paging networks of WA, now after further redundancies and restructures I need to support the Telecommunications 3G network we are building!!!! Most of which I have had no training in and no nothing about!!!!
Interesting times ahead :P
say hi back to two40 -little mobile phone fiend kept me amused at work yesterday - that first message he sent me i thought it was my ex with a new number - its like the stuff he sends me. crappy poems and weird weird things with double meanings. haha
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
