  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
They smell pretty gross Ken. We had a copper in our search team and he identified it was dead body smell! Imagine that "no no that's just dead goanna"..." but wait - this one is a body... 3 days old for sure"
When I owned the wrecking yard we bought a car that someone gassed themself in.
Coppers found him 3 days later in a sealed car in the middle of summer.
Took us a LOT of washing and perfume to even get close to it.
Cheers
Ken
what u mean nice theory
obi wan doesn't meet c3po in the first to movies
but anakin does, he should remember him but seeing there are many doids that look like c3po how is he to know which is the one he created???
droids can easily have there memory wiped ie reformat.
anyway guys - I'm going nighnies..... Gotta get up early for that thing they call a train.... have you guys ever been on one? They are wierd - but I tell ya what i get my $4 worth of entertainment hahaha
God i miss my car
Train...................... Hmmm.............. whats that.
Ohh I know !
There those things that annoy cars at crossings:D
Cheers
Ken
    • I was 99% sure the standard one is long enough to get there, you might just have to change the throttle orientation. If not, I remember someone having used an r31 cable instead, but that is probably harder to find than r33 by now...
    • HELP   Hey all, Is there an accelerator cable from another Nissan that can be used on the R33 GTST RB25DET with a Greddy forward facing plenum?  Thanks in advance  Rob
    • Or do we think it was installed to give 1 bar of boost max, all day, everyday?
    • So could it be assumed it has been installed intentionally with potentially a power FC boost controller kit?
    • Had my rig on Matt's dyno at PITS the other day. After a few years between tunes I added a few sensors and swapped intercoolers. Result. 553hp at 26psi. Not bad for an FJ20 that was built in 2007. The problem.. It filled the overflow bottle on hard runs which leads me to believe the head gasket isn't sealing. I have a coolant pressure sensor which was reading cap pressure at 22psi and occasionally overrunning to 23/24 psi on deceleration after a pull. It was not spiking. It has arp2000 head studs and a cometic gasket. As its been 18 years in service, I pulled the engine out and head off. Everything looks good but we obviously have an issue. Where I'm at.. Years ago I had the same issue, I checked the stud tension and they were all over the place. Some at 60 to 70 and some up near 90. I nipped them all to 100ft lbs and this stopped the water push until now. I believe this compromised the gasket back then. What do I do? 2 options are..  1) I bought arp 625+s, which I could put in with a new gasket. Thinking Kameari this time, reassemble and try again. 2) strip the block, get fire rings machined in with copper gasket and try that. I do not want to push it more than 28 to 30psi. I think the turbo will be out by then anyway. (G30-770). My other concern is the long term ability of a copper head gasket. Are they streetable for years? I feel like a new gasket with the new studs will probably suffice, but I don't know. Any thoughts welcome and advice on copper gaskets and fire rings. Thanks!
