  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
Wally llama Ken and his words of wisdom!
Private PM between sneeza and me.
So nyeh , nyeh:D :bahaha:
Oh shit , He's BAAAAAAACK
pwpt60secf.
And I see micko the slow reader is on. Gotta love 56K modem. It will take him all night to catch up . hehehe
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
Were you just having a go at my staying power? I don't need pills to stand at attention:p
See'ya:burnout:
I may be a slow starter but once I get going.......
Cheers
Ken
Yeah, Micko is the voyeur, he likes to read, but not join in. I haven't bothered to read back yet, seeing as I wasn't here not much would have happened:p
See'ya:burnout:
Thats what you think.
Rooms booked , camera crew and backup is ready , just waiting for the Main Event.
Cheers
Not johnny Farnham again
Ken
I hope you didn't buy too much film:p
Your giving the hand a real workout?
Niz,
Just thinking of you makes the blood rush from my head:p
See'ya:burnout:
Yea niz , god never gave man enough to fill both.
Cheers
Ken
RSI ?? wouldn't waste it on the hand.
    • Yeah, I don't believe the M35 uses a deadhead system.
    • Have you done your thinking backwards? 3 bar, 43.5 psi pressure drop being the presumed specification for an injector, means you need 3 bar upstream when they are firing into atmospheric pressure, and more upstream pressure than that when on boost (you add your boost to your rail pressure to maintain 3 bar across the injector) and you need..... less pressure upstream when you have vacuum in the manifold. So, presuming that you're idling at -10 psi, then you only need ~23 psi in the rail. I realise that I did not need to say all of that to you specifically Matt, once you'd realised your mistake. It's mostly there for complete clarity for others.
    • Have you reached out to the guys at Spool Imports? They are a Ross dealer, I can imagine they would have the rings just sitting on the shelf (I could be wrong).
    • There's one for sale at Grand Auto Wreckers in Lonsdale (SA), for .... let's suggest the sum they're asking for will make you cry. You may have to embrace the idea of modifying the rear subframe to accept some other diff. You could probably find a way to wangle a shortnose into there, with a custom rear adapter and some sort of shenanigans to relocate the front mounts. This has probably already been done by others, so there might be some guidance available as to how easy/impossible it is, out there in the googles. But you possibly needn't restrict yourself to Nissan diffs if you're going to contemplate that. There are similarish Toyota diffs, possibly some Euro ones, possibly some Seppo ones.
    • The ball joint taper and arm taper have to match angle and diameter, but just doing the bushes is a much better option.....seems like the industry moved to "it is cheaper to replace the whole arm than take on the labour for changing this bushes", glad the aftermarket supports it
