  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
On a non sex related subject remember how yous told me 2 buy a turbo? well i thought if im gona get a turbo i may as well go all the way so im gona save up 4 a r34 instead cos 33s r gettin really common and there r hardly any 34s so i reckon bout 2 years ill hav saved up enough maybe less than 2 years at the rate i wrk - being a workaholic!
Originally posted by GTS-t VSPEC
Ken,
You didn't answer my question last night. Do you have the torque figures for doing up the head on the RB20?
See'ya:burnout:
No , I went to bed cos you were all boring.
Talking about cars and stuff.
Why , you gonna help Adam 32.
Can check but only have specs for RB 26.
Ohh and check your PM.
Cheers
Ken
In 2 years time R34 's will be common
Cheers
Go the 32's
Ken
Originally posted by Nizmo
betty is easier to find hehe.
ooooo relationship - thats a very big word for a guy haha.
might have to go to bed soon im not very well - need male nurse *batters eyelids at paul*
What , more Battered eyelids.
Who keeps hitting you ??
We will kill them won't we pwpt60secf:D
Cheers
Ken
yes in two years time we can all upgrade :D but for now im very much attached to whats under the carport it keeps me broke enough as it is.
Can't be too attached , your trying to boot the Z out. Hehehe
Cheers
Ken
Yeah, checked my PM *keep it secret, keep it safe*
I think they are all the same, but don't know for sure.
33Spec2, Start saving, nice cars, but I'd go for an R32 GTR:p
See'ya:burnout:
If you are going to then PM her ( no , not you Loz )
:D
Cheers
Ken
easy to personalise - see a few R33's but the only time i see any like mine is when i cruise with you guys and theres 4 cloned black ones all in a row - lucky for me theres only four other people dumb enough to buy black haha
im not trying to boot Z out my folks are :D mum cant get to her porsche with it in the way - but that gets driven as much as me Z anyway - its a convertible so she leaves the roof off for all the spiders to inhabit and the rain to blow in hmmm not the smartest move.
