  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
definately have to get this suspension fixed asap - dragging a motorbike on the way to work - doing pretty well considering he was 10X lighter than me then i hit a rough patch of road and with a squeel of the wheels hehe i decided the car couldnt hack the surface grrrrr. was having so much fun!
car giving you dramas Niz....
took the rex out to High Wycombe last night to vist me best mate... first time ive drive the car in a week.....
forgot how many dips**ts are on the roads in the crappy cars who want to drag you....
1st - P Plater in Mirage with his tart girlfriend pulls up at the lights and starts reving the crap out of it.. i though he was joking so didnt bother.. lights turn green and this fool drops the clutch and burns off at his blistering pace (hahhahah).... i causely drive along next set of lights same story.... except he looks over laughs and starts reving againing thinking that he just blew me away hell embaras me again...
fark that 5K clutch drop and see ya.... idiot. comes flying up ..."what you got in that thing???"stupid tool...
Dan
Since i bought my private plates I haven't been able to find a single drag except for people in lancers or 1945 model pulsars!??
I pull up next to a V8 who has been thrashing it between cars the whole time just give it a bit of a rev to let him know I am there and he didn't run....
I really want to give that lotus a run Dan that i was tellin you about.... I might not win but it would be a gun run... might come close though :-) once ITC is on (Finnaly!!) will be pulling 290 so should be a good run!
2nd - tool in V8 falcon driving up my ar*e, i pull over to let him through, and flys past. Get to lights and Trev and Pete in the V8 are getting ready to roll.... tools
what is it that every time you take the car out sh*tboxes want to race you.
Dan
hahaha nice work dan!
i see the wrx is still providing u some entertainment
dun worry
on the way to work
some gangsta tried draggin me in his try to be evo lancer
i was like okay then HOWABOUT NO!
hehehee
****sticks
Sup Niz, how r ya? you know the prices u put up before from wilkinsons and wa suspension were they for springs and shocks
or for full coilovers? adrian :D
Me had some fun last night, practicing lauches against my mate's wrx... jeezus those things grip!
Needless to say I don't! I was trying to practice lauches to see if I'd be any good on Sat.. every single time was huge and I mean huge wheelspin... he even beat me at one stage - imagine that! a wrx beating the mighty power of the skylor?!?! Luckily I got traction sometime into second and showed him skylor power! yea!
hehehe.. sorry - early morning boredem setting in at work already!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
