  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mods - afc & itc (which I'm convinced aren't tuned properly), intake pod, cat back exhaust, 12.5 psi boost, external bov and blitz piping (probably no different to std)... nothing super special - but apparently can do 230 at the wheels... tho every dyno is different...
Originally posted by GTS-t VSPEC
Hey, I resemble that remark:p
See'ya:burnout:
Hey where is that a quote from???
On a side note: Prank is coming over here to look at some cars, so i might take him and his fiance to the Whiteman park carshow thinghy any1 wanna come?
had it about 9 months (i think?) - all came with it when I bought it.. i've put in a fuel cut (pivot racing tool - extra rice!) myself - but thats about it.. not interested in doing much cept for service it (oil and filter change) myself...
how bout urs? :(
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
