  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Wreck his car? Cool, I'll bring the axe:p
Rays workshop is airconditioned:p
See'ya:burnout:
Rays w/shop is only 100sqm , this is 280 sqm and evaporative sucks on a humid day.
Cheers
Ken
You and 1/2 of SAU WA going to help Adam 32 wreck his car
you wannah get in on it ken? hehe
i figured 5 no brainers should be able to do the job of a qualified mechanic:D
actually one guy is comin down who actually knows what hes doin, the rest of us are just gunah drink beers and have a bbq
There is no need to comply them, plus you can get away with more of the aftermarket gear they come with, so it's the route I would take. Planning on a full rebuild anyway.
See'ya:burnout:
Correct if you are willing to rebuild but people will expect a mint one.
Most 89's I have seen on the auction site sound well hammered.
Gotta remember in 89 they were a new novelty.
How many good 94 rexes ya seen ??
Cheers
Ken
I saw Wholagans car today, it has just been tuned, and they now have a dog-box with straight-cut gears. All they need is a decent driver:bahaha:
See'ya:burnout:
Jamie is actually a fair peddler though his dad could do with some smoothness lessons.
I think it would be a bit of an animal tho.
btw page ownage hehehe
Cheers
Ken
I thought that seeing as you posted 2 x posts over 3 forums that some one might have a clue by now.
Would love to help ( drink beer that is ) but have an R that is looking to go east ( I hope )
Cheers
Ken
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
