  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i was talking about EVL R33 but yes macka in a better form can whoop my arse too. nah i seee no poin tmaking a idiot of myself theres far more worthy cars the deserve to run than mine i'll just stick to my more playful gigs i do on the street that i shouldnt really do but i do anyway. Pretty funny friday night one of my friends dads Type R's went passed so i waited for the lights to go green and caught up in the process of doing 100 in a 60 zone i passed a radar on the other side of the road - i slowed right down fro the next 10kms just incase they decided to get on the CB and get soemone to pick me up late on down the road haha
everyone speeds - fact of life - you dont have cars like ours to drive like grannies anywhere! besides the only private road i used to love has become public so bugger it i will still speed on it - cops are a raretity on it anyway. Its the only way i let loose with built up anger the more pissed off i am the harder i drive.
i dont know i like drivers that challenge my skill - weaving etc lurve it except when im blocked in by soemone in the left hand land and someone in the right hand land doing the same speed aghh most annoying! After two beers and a bad day - hell i can drive :P thats all it takes and im queen of the road - well so i think anyway!!
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
