  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
i was talking about EVL R33 but yes macka in a better form can whoop my arse too. nah i seee no poin tmaking a idiot of myself theres far more worthy cars the deserve to run than mine i'll just stick to my more playful gigs i do on the street that i shouldnt really do but i do anyway. Pretty funny friday night one of my friends dads Type R's went passed so i waited for the lights to go green and caught up in the process of doing 100 in a 60 zone i passed a radar on the other side of the road - i slowed right down fro the next 10kms just incase they decided to get on the CB and get soemone to pick me up late on down the road haha
everyone speeds - fact of life - you dont have cars like ours to drive like grannies anywhere! besides the only private road i used to love has become public so bugger it i will still speed on it - cops are a raretity on it anyway. Its the only way i let loose with built up anger the more pissed off i am the harder i drive.
i dont know i like drivers that challenge my skill - weaving etc lurve it except when im blocked in by soemone in the left hand land and someone in the right hand land doing the same speed aghh most annoying! After two beers and a bad day - hell i can drive :P thats all it takes and im queen of the road - well so i think anyway!!
    • Did you panel beat the dents or have you tried to repair this only using filler?  Is your sanding block soft/flexible and is following the shape of the panel rather then just knocking down the high points?
    • I haven't knocked them down yet. I think I made the repair more complex than it should have been. I had rock chips combined with waviness and dents and I tackled it all in one because it was near each other and just end up wasting a bunch of bog lol. I'll knock down those areas and see how I go. And yep what you are saying at the end is correct. I think I might be sanding the top of a steep hill then my sanding block falls into the dent and gets rid of the guidecoat if that makes sense. Though shouldnt unless I'm covering too big of an area with not a long enough block. I'll try something new and provide some updates. Getting there though! Thanks as always.
    • Yeah makes sense, hard to comment on your situation without seeing what your doing. I was talking generally before, I would not be looking to randomly create low spots with a hammer to then have to fill them.  It's hard without seeing what your doing, it sounds like you are using the guide coat to identify low spots, as you're saying the panel is still wavy. I don't see how you're not ending up with patches of guide coat remaining in a wavy panel? Once the high spots are knocked down to the correct level, surely to have a wavy panel you need low spots. And those low spots would have guide coat still in them?
    • So I'll put filler past the repair area a bit to make sure I don't miss anything. Then I'll block it until it's almost level, put the guidecoat, then keep blocking until it's gone. Then it's still wavy.  In regards to hitting the panel, I saw this video might give more context - Skip to 0:47 he knocks it down. But yeah I'm sanding until the guidecoat is gone then checking because otherwise my filler is still well above the bodyline. Unless what you're saying is I should put guidecoat around it early, surrounding the filler then stip once it's gone?
    • I refreshed the OEM injectors with the kit and connected it up. It now ideals okay even with the IACV removed. Driving still has the same cutoff issue like the 550cc injectors so the issue is somewhere else. I bought FPG's Fuel Pump Hanger. I will be installing it next, but it is not as straightforward as I thought it was with my limited wiring knowledge and no instruction on the specific model I purchased (FPG-089). I also got the incorrect billet clamp as I could not find info on the OEM sizing.
