yeah i try to keep the crap in my car limited - if its not practical throw it out. My friends only hav ethe right to sit down and shut up in my car otherwise they get left on the side of the road - they respect that! I had one mate who was a little too vocal on the driving technique aghh i hate backseat drivers i nearly kicked him out on several occasions - if he doesnt like it he can drive his commonwhore!
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
MMMM
Bonking techniques
* hay darl , come here , I wan't to try out something I learned *
Nope , didn't work. Still can't work em out.
I think Prank is after a stock one which leaves rice racer a bit out of it.
Cheers
Ken
Originally posted by GTS-t VSPEC
Hehe, I like your attitude Niz. Most of my passengers are too scared to talk:p
See'ya:burnout:
Ahhhh , I see..
So its
Get In
Sit Down
Shuttup
Hold onto this.
Ooooh , that's nice
Cheers
Ken
PS Page ownage hehehe
PPS RR ( Rice Racer ) has a 1/2 cage I think
oh my mum suffers from car sickness plus she drove my car while i was away - heard the turbo whizzing didn tknow what it was thought my car was sick hmmm - while my battery was flat on saturday i was drfiving her car everywhere (bloomin marlows three times befor ethey worked out what battery an R33 took then proceeded to bag imports in front of me) and for a 60,000 dollar car she got ripped take the line anyday instead of that thing hate driving it!!
I heard Wholagans car didn't last too long, the CDI packed it in.
See'ya:burnout:
Worked fine on the dyno I believe with 477 rwhp but in the heat of battle at the track started breaking down.
I believe Richard Aubert had better have some KY lube ready...
Cheers
Ken
*Note to self* No back seat Drving on Sunday :uh-huh: :P
cheers
Joe
i dont car who goes DJ in my car they only have a choice from my CD's anyway!! plus ive got a bit of everything so we can usually agree on something - hmmm but Joe's attempt at the Vengaboys in my car - not on!!
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around with a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
    • Yep, this bit another local owner. I caught it before putting the transmission back into the car, what I noticed was the pressure plate fingers weren't flat and even. It's more obvious with the pull style clutch because the throwout bearing ring was visibly not flat once everything is put together. Nismo should really update their instructions to call out this specific detail. I'm not even sure the clutch as-shipped orients everything properly.
