Originally posted by Nizmo
yeah i love my car wouldnt have anything else just the fustration oooo the fustration haha.
burnt my tongue on my hot choclate *sniff*
i know why u wear high heels
so average hieght guys have to stare at your ass when u walk in front of them??
hot chocolate sounds yum
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hehe no it cant be the suspenstion anymore because that cant get worse! the wheels are vibrating back n forth so its like they have suddenly got desprately out of alignment and i dont want to shell out fo rnew tyres as well
