  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Hey Ken, that ain't my cup-o-tea, stop mixing up our sex-lives:p
Still looking for some stock R32 GTR rims:p
See'ya:burnout:
whaddya mean our ?
you mean yours bud:D :shake:
I am after a set yes , if the price is right cos I sold the set of the race R and need some rims for the comp rubber.
Cheers
Ken
Originally posted by 33Spec2
Rain? hav you had a cruise in the rain b4? hmmmm lots of drifting!
If it's raining and I'm there , you had better not be drifting anywhere near me !
I think I know what I'm doing but drifting , rain , public roads , traffic , kerbs is a recipie for a busted car:(
Cheers
Ken
Originally posted by Micko
Nup - you never gave me a copy.
I don't recall any lies, but feel free to tell me about them - I know you used to have your own car yard (D & K Autos methinks), so I guess it's in your blood now, eh?
Nah just kidding and you are right , I did own D + K autos , which stood for Dirk and Ken but was often referred to as Dick and C**t
Cheers
Ken
Cheers
Ken
Well put Ken - in fact no rain & kerbs can be quite an issue as well;)
