  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by 33Spec2
It was a vspec! (EVL_R33s)
Brett's car is way down on power atm cos he got a sad terb.
pulled quite low figures on Hendo's dyno.
But a set of 2530's and a power FC will change all that.:)
Cheers
Ken
Originally posted by GTS-t VSPEC
Ken,
There can't seriously be that much difference, can there?
See'ya:burnout:
No theres not but the aesthetics are what does it for me.
Sort of like Kylie minogue versus Roseanne Barr.
Cheers
Ken
Jaffo???
Yeah i should b there on sun if thats ok! ill try and get some chicks 2 cum along!
Ahhh chicks
Things are looking up.
But don't forget that your mum in the passenger seat doesn't count
Cheers
Ken:D
    • I was just driving into work and while on my drive, I went to accelerate and noticed the car would sputter/hesitate and I’d hear a few pops from the exhaust before it started going faster. Then I also noticed that when I push my clutch in, the car would die. This all started happening today. Any ideas?
    • That is a lovely Volvo, just saying. Yes I should have got an 260RS when they were cheap. I do regret now.
    • ^ lots of good points made above. The thing is, "aggressive" or "flush" fitment is relative depending on how much you have been influenced by social media. My starting point is always "look at the Nismo RWD specs". That is where you should start, then start measuring as GTSBoy as sort of mentioned, because every car will be slightly different. My 8.5"+35/9.5+38 will not be "flush" enough for you because you want more "pumped" look, which is why you measure. Tyre sizes and brand/models also make a difference. Some tyres are more chunky/square, some are more rounded. That means you could get away with more aggressive offsets without rubbing. But then it also depends on your ride height. Also depends on how much your car copped damage before being shipped from Japan. So it goes back to measuring your car yourself and determining what can work. Those Nismo specs are used bacause it's a safe spec for standard car (suspension. body) with chunky tyres. But then I put 265/35 wide tyres on R34 GT-R wheels, and currently run 285/30 tyres on 18x10 wheels.
    • Sounds pretty awesome. I recommend creating a new build thread and posting all your goodness in there.
